Old 12-02-2020, 10:01 AM   #1
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
ESC enables itself on it's own?...
Has anyone experienced ESC enabling on it's own?
I was out tuning, in Competitive Mode (SPORT), and after a couple WOT blasts from a dig and slow rolls, I noticed that ESC turned itself back on. I got no warning lights or anything like that. I THOUGHT that I caught a glimpse of a message in the gauge cluster, but I was too late, and if there was, I couldn't read what it may have said. It was like I just missed the window of the message closing (like the same window when you receive the Competitive Mode being active).
Anyways - I noticed this right after one of the runs. I was able to turn it right back on with no problems. I totally forgot to check DTCs when I got back home just because I forgot, so I don't have any of that information. This is at least the second time I've noticed this happening. From what I can recall, I do remember the car getting pretty loose out back, and feel like that is about what happened the last time this occurred. I'm not certain there is a relationship or coincidence though.
Has anyone noticed this kind of thing before? I don't recall reading anything in either the Owner's or Performance manuals about ESC turning itself back on in an circumstances. I do recall that Cruise Control cannot be enabled in Sport (or Track modes), but I wasn't messing with any of that. It just seemed to enable itself of it's own... Any feedback would be greatly appreciated.
Thanks,
Chuck
'20 ZL1 Black "Fury"
Old 09-20-2025, 12:22 PM   #2
Barefoot Dave
Barefoot Dave
Barefoot Dave's Avatar
Drives: 2021 ZLE & 2022 2SS 1LE
Did you ever get this firgured out?
Dave M
Barefoot Dave is offline   Reply With Quote
Old 09-20-2025, 12:24 PM   #3
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
99.9% chance of an inadvertent press of the mode button.
Old 09-20-2025, 01:08 PM   #4
Barefoot Dave
Barefoot Dave
Thanks for that but it's happening in my ZLE on track and street...100% chance of NOT an inadvertent press of a mode button. Bizzare because it happens randomly and I have not found a pattern yet.
Dave M
Old 09-20-2025, 01:10 PM   #5
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
Remove your rear tire and inspect the ABS harness that runs along the fender liner. I had that issue once and it turned out to be that the tire rubbed through the harness and through the wiring insulation.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% lower, Griptec 2.5 upper, NGK HR7 Ruthenium plugs, Nostrum 22+ injectors, XDI Goliath HPFP, Katech dual in tank low side pump, Katech oil pump, LME tensioner, DOD delete, LT1 big fuel cam, Jokerz ported blower, MPI lid, GMS hood extractor bracket, Soler ported 87mm (91mm eff) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, 186* LS3 T-stat, Black Widow Angry Housewife/ Corsa NPP mufflers, Borla X pipe, BMR engine mounts, Banks iDash, Lithium Battery, AEM X- Series, HP Tuners, E85, 16.5 psi
834 HP/ 840 TQ
ZLRob is online now   Reply With Quote
Old 09-20-2025, 01:13 PM   #6
Barefoot Dave
Barefoot Dave
Thanks Rob....I'll do that now.
Dave M
Old 09-20-2025, 07:18 PM   #7
The harness is on the driver side
Old 09-20-2025, 07:20 PM   #8
Barefoot Dave
Barefoot Dave
Thanks-I found the harness, but that’s not the problem. I’ll take it to my mechanic on Monday. I don’t have a code reader that reads suspension codes but I’m guessing there’s one in there and we’ll get to the bottom of it. It doesn’t in all modes and is very intermittent.
Dave M
Old 09-22-2025, 08:04 AM   #9
65ffr
65ffr's Avatar
Drives: '18 ram 1500
In Competitive Mode, ESC is supposed to be on (TCS should be off tho)
2023 ZL1 Radiant Red 6 spd, pdr, carbon fiber hood
1100 10/28/22
2000 12/6/22
3400 12/17/22
TPW 1/9/23
delivered 2/7/23
65ffr is offline   Reply With Quote
Old 09-22-2025, 03:49 PM   #10
DeuceCam
Drives: LT1
My thoughts exactly.
DeuceCam is offline   Reply With Quote
Old 09-24-2025, 01:09 AM   #11
clj94104
Drives: Camaro ZL1
Any updates?
clj94104 is offline   Reply With Quote
Old 09-24-2025, 05:19 AM   #12
Barefoot Dave
Barefoot Dave
Originally Posted by clj94104 View Post
Any updates?
Yes- he found 15 volts going to the body control module during situations where the traction control or ECS would normally be needed if it was energized - and it should be no more than 14. So far he cleaned several grounds and it appears to have fixed the problem.
Another test drive today and we'll see!
Dave M
Old 09-26-2025, 07:32 AM   #13
65ffr
65ffr's Avatar
I could understand dirty grounds causing the voltage to be lower, not the other way around tho.
1100 10/28/22
2000 12/6/22
3400 12/17/22
TPW 1/9/23
delivered 2/7/23
Old 09-26-2025, 11:13 AM   #14
Barefoot Dave
Barefoot Dave
I agree...but I don't know what to tell you. It's fixed....off to Daytona!
Dave M
