![]() Drives: 2021 Camaro ZL1 A10 Join Date: May 2013
Where to place 4 jack stands?
Ask a simple and redundant question, and a great answer may result.
When setting the car on 4 jack stands, where is the best points to place the jack stands? As I understand it, the pinch weld is not the idea spot, and I plan on installing ZL1addon lifting blocks. Sledgehammer70 says not to use jack stands on ZL1-Addons lift points. I know there have been numerous threads on this, but there does not seem to be a consensus? So what is the latest? |
![]() Drives: 2020 2SS 1LE Join Date: Jun 2020
I have lift blocks and use them on my standard jack stands without concern, even when applying 148 ft*lbs via torque wrench to the front caliper bolts. The only downside is that your lift blocks will get marked up.
Even if I didn't use the lift blocks with jackstands I highly recommend installing lift pads to make it less likely that a tire/service shop lifts the car incorrectly (very common) and bends your front quarter panels. I agree that painted metal (jackstand) on anodized metal (lift block) is not a great interface but I felt that adding rubber pads to the tops of my jack stands actually made it more unstable. Just make sure to carefully center the lift pad on the jack stand. The perfect solution is the ESCO jack stands with the lift blocks, I'll pick up those jack stands at some point in the future. |
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
I am not understanding what you are trying to say.
The ZL1 Addons Lift Pads are for your lift or jack stands, while the ZL1 Addons Mag Pads are what you use with floor jacks. The Mag Pad is not supposed to be used for the jack stands, but the Lift Pads are. I just follow this video on how to jack up the car. Pretty comprehensive video.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
Try the ZL1 Add-on MAG pad w/puck. Goes in the center and Jacks both front and rear tire at the same time.
Then like the video already posted, if you still want some jack points on the 4 corners for shops and stuff get the jack pads. I would not jack on the pinch welds without either Jack Pads or the Mag Puck. |
#5 | ||
#6 | |
I actually have all of those products from ZL1-Addons. I intend to place the jack pads on the far forward pinch welds and on the aft pinch welds. Then use the second forward pinch weld to lift with the Mag pad. MLee, do you agree with the placement of the jack pads in the video. He says he's done it hundreds of times. I am just looking for some consensus. Generally if something works everyone does it. |
#7 |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2017
I do it the same way. I then place the jacks under the lift pads. My jack stands are the deep “U” style, and the lift pads sit in them nicely.
#8 |
![]() ![]() ![]() ![]() Drives: 23 ZL1 6speed Join Date: Aug 2020
I haven't perfected the art yet, as I've only lifted the car a couple of times so far. I'm actually looking to get a new jack this week, so I'll find some excuse to use that haha.
I have to lift pads installed on my car, 4 standard (u-shaped groove) jack stands, low pro jack, and pinch weld adaptors for the jack stands (hefty rubber blocks that basically slip onto the jack stand). To answer OP's question - I've always (thus far anyway) used the pinch welds for the jack stand placement. I personally don't think that I would use the lift pads because I feel they're not as stable while raising/lowering the car. You don't have the "track" of the pinch weld that keeps the stand in place, even if it is ever so slightly. |
#9 |
![]() Drives: 2021 2SS Join Date: Jul 2020
Honestly, the only good way is buying the lifting pads from Amazon (same as the ZL1 add-on ones for cheaper) and installing in all six positions. So you will need two of the 4-packs.
Once installed, lift with a jack (with a hockey puck or pad) using the 2nd position from the front. Then place jack stands under the very front and rear position jack pads. Then repeat on the opposite side. I also have jack stand rubber pads that give more 'grip' on the lifting pads as extra insurance they don't slide on the metal-to-metal contact. Jack stand cradle to be perpendicular to the jack pad. This is the only way I got it to work well. I don't like the magnetic lift pad adapters, I had one tilt/slide out when lifting and gave me a heart attack. Thankfully, no damage. Once I had all the lift pads installed, lifting has been non-issue and far more stable/safe. Last edited by Invertalon; 11-30-2020 at 09:58 AM. |
#10 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
subscribed as i will probably be doing this for when i install my exhaust myself
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
#12 | ||
![]() Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert Join Date: Feb 2019
#13 | |
#14 | |
![]() Drives: 2019 Satin Steel 1SS 1LE w/ PDR Join Date: Sep 2017
I want to know why ZL1 Addons now specifically says not to use the pads with jack stands. I don't remember that explicit warning until pretty recently. My guess is someone did it wrong and the car slid off. The way my jack stands fit "in" the pads feels as steady as it can be. I also know that the car was designed to have the weight in this area. With that being said, the fact that ZL1 Addons now says this gives me great concern about doing it again. |
