![]() Drives: 2017 Camaro 1ss A8 Join Date: Nov 2019
1st gear is useless
Hey guys, I currently have headers with x pipe, intake, and e85. I ran a single cab Chevy 2014-2018 5.3 with the same bolt ons and e85 tune from a 20 roll. We are tuned by the same shop (New era in socal) He said 20s were a good roll for him. So I gave him his 20 and We ran it and I spun so bad in first and had to play catch up to end up winning him by 2-3 cars. Especially with this cold weather i don’t think I can do a 20-30 roll. Need to be at least a 40. Any similar situations
![]() Drives: Chevrolet Camaro SS 2018 Join Date: Jun 2019
I dunno if theres any common consensus on rolls but to me, a 20 roll makes absolutely 0 sense. Might as well take it from a dig then. 30-40 rolls sure but 20 is damn near a standstill anyway
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
I mean, you are comparing against a truck with more weight and maybe even 4WD. I once played with an Audi RS3 a bit and I couldn't catch it unless we get to very illegal speeds because it has AWD and I don't. Doesn't help that GY SC3 isn't very grippy when it's cool outside.
My stock SS 1LE with a 6-speed manual will spin the rear tires in 1st when I floor it unless the conditions are very good. It's just the way it is, especially if it's cold out. Something that can help is to feed the throttle to the floor rather than just abruptly floor it. Throttle control is pretty important in situations like this, though even that will have its limits.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
Yea he said his 20 rolls were his best and he said he knew he’ll loose if we went from a 40. So I just gave him what he wanted. Forgot to mention I’m also on stock 275’s with about 60% tread left.
I agree, no way I can do WOT in 1st and/or 2nd regardless of the tire or weather. Rolling in 3rd gear at 30 mph is doable but it still might break loose in Manual. I never use Auto except for cruising. The downshift at WOT is a killer.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
![]() Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
It’s just physics. Same thing happened to me. Some ding-dong in a pickup was calling me out at a stoplight on a cold fall morning. When the light turned green, my traction control strangled the car so bad I thought I broke something. I went past him about 200ft later at warp speed, but it was painful to watch. 😀
Unless you do a massive burnout and then immediately do your 20 roll, I think your results will always be the same. |
#7 | |
![]() ![]() ![]() Drives: 2020 LT1 M6 Join Date: Jan 2016
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
when my 1LE was stock it would dead hook first in the summer and down to about 65* if i cleaned the tires off first.
basically fbo now so first gear is useless at any temp and second gear as well under 65*.
#9 |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2017
No doubt about it....you need to run DRs.
#10 |
![]() Drives: 2018 2SS 1LE Join Date: May 2020
Bone stock 1LE here, ps4s. Car hooks great above 70°f. Below that first gear has poor traction at WOT, second gear is still quite a handful when no lift shifting. Doesn't feel solidly planted until well into 3rd. Once it gets below 60 I turn off competitive mode and just drive in sport. Suspension always set to track.
#11 | |
Sent from toaster or something
Current:
#12 | |
#13 |
![]() ![]() Drives: 2021 Camaro LT1 Join Date: Sep 2020
Nail my new 2021 LT1 from a slow roll and it is sideways. Stock tires don't cut it.
#14 |
![]() ![]() Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
My 2 SS A8 will really spin at 20 WOT. Launch control works very well though from a stop (convertible which is heavier). Won't beat many cars from 20 WOT due to traction issues but sure is fun.
