![]() Drives: 1985 Oldsmobuick Join Date: Oct 2012
Which billet thermostat housing + thermostat?
Which brand billet thermostat housing, which thermostat to go with it and which temperature?
The Katech looks good but which temperature? 160 or 174? Which billet housing will it fit? Any other suggestions? ZLE used for road racing. |
I have the 160
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
Moderator
Katech is the only tstat to use IMO. Mishimoto, Weapon X, etc are all junk and will overheat your car when they fail. Use the 160 if you are tuning your ECM and use the 174 version if you need to keep the stock tune.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
Katech
Flying around Thailand
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
Do you have to tune your ECM to use a 160???? How the hell does the ECM know this? these new cars are wild. I remember when I ran a car without the thermostat totally (froze closed so I removed it). Ran great for years without it, just took a while to warm up, and never got warm to hot..... Anyways, wow, new cars man, amazing. Since I live in hot-ass Udon Thani, Thailand, I'd love to change my Thermo down as far as possible. Its damn near December and it was 94 today. Went to the CRV to get the tools to fix a seat belt issue on a friends car and the socket roasted my hand and my CRV windows are totally shaded. There are thre seasons here, Hot, Very Hot, and Freakin Blazing. So the 1st thing I do when I get the ZL1 next week is protect her against the sun. So a low Temp Thermo would be good.
I do not believe a tune change is necessary for the 160F as I don't believe HPE tuned for mine.
2020 ZL1LE A10.
#7 |
Moderator
False. If you don't change the mechanical thermostat setting in the tune, you will get a code for the car not coming up to the expected temp.
#8 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
https://briantooleyracing.com/amp-bi...5-amplt4h.html and a Katech 174 Thermostat.
Tune is needed for a 160°!!
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: SwissZL1 |
#9 |
I've never gotten that code and it runs when hot at +/-185F but it takes awhile to get up there. I'm not convinced there's any measurable benefit of this thermostat.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 11-22-2020 at 12:54 PM. |
#10 |
Moderator
Your car is tuned, so you wouldn’t get the code...
#11 | |
Moderator
With the Katech 160 thermostat and new fan settings (see second pic), my car cruises in the 170-180 degree range, which is perfect IMO.
#12 |
Thanks for everyones input.
#13 |
![]() ![]() ![]() ![]() Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
I change the tstat in my C7 and I dont believe it required a tune, however, the fans needed to be adjusted in accordance with the tstat. I would suspect it would be the same for the ZL1.
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
Interesting, I ran a 180 degree Mishimoto in my Hellcat for almost 4 years without issue.
