Old 11-13-2020, 02:11 PM   #1
JasonGofast
Used to own a ZL1
Drives: '16 Z06
Wheel size effect on straight line performance?
Looking to get 19 inch instead of 20 inch wheels for wider tires. Will this have any effect on straight line performance? I know the car will need to be tuned to show the correct speed.
JasonGofast is offline   Reply With Quote
Old 11-13-2020, 02:15 PM   #2
Z OH 6
Drives: 2024 CT5-V Blackwing
Depends on the overall diameter of the wheel/tire combination, if the diameter is larger, then it will effectively raise the rear end ratio, if the diameter is smaller, it will effectively lower the rear end ratio.
Old 11-13-2020, 02:29 PM   #3
Markoz28
Drives: 18 ZL1 nightfall grey A10
If I went with 19s it would be a 19x12 and I would put on a 345/30/19 R888R. If I stayed with 20s it would be my current 20x11.5” with 325/30/20 R888R.
Markoz28 is offline   Reply With Quote
Old 11-13-2020, 03:01 PM   #4
JasonGofast
Used to own a ZL1
Drives: '16 Z06
Yes I'm considering something like that. I just want to know if it'll make the car slower in any way. Talking tenths in the 60-130.
Old 11-13-2020, 03:12 PM   #5
Markoz28
If your car is stock it may slow it down in the 60-130 but not by much.
Old 11-13-2020, 03:40 PM   #6
Z OH 6
In the 60-130, if the car needs traction it could help with a wider tire but if the car isn't currently spinning at 60mph, then a wider tire is going to make you slightly slower due to more tire friction.
Old 11-13-2020, 06:10 PM   #7
FoundNemo
Drives: 2019 ZL1
I swapped to APEX ARC-8 19x10, 19x11's with 285/30R19 PS4S tires and 305/30R19 R888R's in the rear. Nice torque increase from the effective gearing change, fantastic grip, notably quicker and peppier all around. 32lbs or so lost rotating and lower distance from centerline, so much less rotational inertia. Calculates similarly to the GT350R vs GT350 differences overall, about 0.2-0.3 gain assuming traction.
FoundNemo is offline   Reply With Quote
Old 11-14-2020, 10:48 AM   #8
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
Assuming Traction..... and that's usually the crux
Bangkok_ZL1 is offline   Reply With Quote
Old 11-16-2020, 06:54 AM   #9
FoundNemo
Drives: 2019 ZL1
And thats why I have R888R's
