Old 11-12-2020, 02:00 PM   #1
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Left drive shaft thicker, than the right??
Had my car on the lift today, and noticed one drive shaft is alot thicker than the other one.
Can someone explain why?
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 11-12-2020, 02:07 PM   #2
GasmanCTSV
Drives: 2016 Cadillac CTSV
Yes, totally normal. It’s to prevent wheel hop under full throttle acceleration. 1st gen CTS-V had it bad...Now all Vettes, CTS-Vs and I assume most Camaros have this.
GasmanCTSV is offline   Reply With Quote
Old 11-12-2020, 04:45 PM   #3
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I seem to remember my 2010 SS was that way too as well as my 2017 ZL1.
Old 11-12-2020, 05:12 PM   #4
HDRDTD
On the 5th gen ZL1's, one is solid and smaller diameter, while the other is a larger diameter but hollow.
I don't remember the physics behind it, but they did it to reduce wheel hop.
