![]() Drives: 2017 ZL1 Join Date: Aug 2020
Can I get another 50hp for under $2000?
2017 ZL1 A10 with ported tb, LT's with high flow cats, 9.17 lower pulley, e85 sensor, roto fab and tune. Currently about 645/685.
Wondering how to add another 50+hp for less then $2k without doing any fueling mods other then possibly a low side boost a pump and having this thing continue to run cool enough for road racing? |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
With the lower pulley increasing boost you may already see increased temps on road course. You might need to look at cooling upgrades. JMHO
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
With a pulley and the big power increase you already have, your car has already lost a lot of cooling capability on a circuit. On a warm day, maybe any day, it will overheat. Have you tested it yet?
If you add anything else, it will get hotter. You could look into this: https://jannettyracing.com/collectio...019-camaro-zl1 It uses no pulley, stays cool on track and boosts power to 800+ BHP. You don’t need more than that on track except DSSVs, wide R comps and ZLE aero to beat anything but a 720s or similar, if you become a great driver. |
BAMF SS
Meth
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
![]() ![]() Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
ported blower and 103tb?
#6 | |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
x3 for the ported SC and 103TB. This will free up air flow and reduce restriction. It will decrease your PSI and reduce IATs a bit. Might reach your goal there but you will be completely maxed out of fuel at that point.
All of this sets you up nicely for a cam in the future. |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
#9 |
![]() Drives: 2019 Camaro ZL1 M6 Join Date: Nov 2018
I wish I could explain how with close to the same mods as you (rotofab/LTs (catless)/9.17 lower) I am making 717wtq. Seems so weird.
#10 |
as i learned recently with my build, take a look at your dyno sheet and see if your numbers are using SAE or STD. Example, mine was given to me as uncorrected, but if i apply STD correction as an example my number goes up appx 40rwhp.
#11 |
True but many dyno operators will use STD on these Gen5 LT A8/A10 cars because they do not dyno them in the 1:1 gear which makes the numbers read 25-35whp low. So using STD correction in Non 1:1 5th(A8)/6th(A10) will yield similar numbers to using SAE in 1:1. Even then no 2 dynos read the same even if all variables are the same. Especially dynos in high elevation.
#12 | |
The torque gain just seems so much higher than others that I have seen. It honestly has me considering trying another tuner just to make sure its all good and not leaning out too much on initial acceleration.
#13 |
Could be how the timing map is set up by the tuner. Some pull a lot of timing in the low-midrange part of the timing map to soften the torque. Others run a lot of timing in that area which will make a lot more torque on the hit.
#14 |
I went back and checked the dyno sheet from Cordes after they installed a cc.
642hp/698tq SAE on a 108 degree day using e40. I've been to one 1/2 mile track day with this car and 1 day road course though I've been roadcoursing for 20 years. On the wildhorse east track in Phx a few weeks ago that started out at 68 degrees the first session but by the 3rd session was 93 degrees. Watching the cars temp readout for trans (max 223 degrees) and the aeroforce gauge for coolant and oil temp (max 238/246 degrees) I was pleasently surprised to see no overheating. Perhaps running e42 helped? The east track is relatively small with a short straightaway (120mph max) and technical with lots of turns. I've leaned toward porting the blower and then going the bigger tb and big gulp, but Cordes thinks I'll be running out of fuel with that arrangement, even with a low side boost a pump. Seems I'd be pushing that 700wrhp mark then and I thought the low side boost a pump would take care of that, but I admit Cordes has a whole lot more expereince with these then I do. He suggested a cam for power and fueling, I'm just not sure I want to go into the engine and then I'd reason, hey while you're there...port the heads as well. Next thing I know I'd be into it $6k vs below $2k. Yikes! |
