![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Driver side motor mount leaking?
So car is in the shop today for a few small mods and a retune. On their inspection they found the driver side motor mount to be leaking?
Just surprised as the car doesn’t get driven hard and only has 18k miles. Is this common ? I’m not familiar with these mounts, they have fluid in them? If this is true and leaking should I have dealer replace it or get aftermarket mounts? If you have suggestions or part numbers please let me know. Pic attached. |
![]() Drives: 2017 Camaro ZL1, 6M Join Date: Dec 2019
My car (a 2017 built in may of 2017 with 12600 miles) has the same issue. I plan to replace with an OE component.
Moderator
Fluid filled mounts help reduce NVH in the cabin. Sounds like you just have a defective one. Can’t say I’ve seen many (if any) posts about this before, so I’m assuming it’s not common.
Yeah looks like its just best to use the oem ones, as i hear the BMR ones transfer alot of vibration inside the cabin.
Ill bring it to the dealer soon and have them replace it. Lets see if they do it under warranty. |
Sarcasm loading --------
I broke one before at the race track. they will break if you do hard launches in your car.
I replaced with BMR solid mounts and never looked back. track tech threw me off the track - said I was leaking oil all over the track surface. went back and found not a drop. ran again - he comes back yellign at me some more; but again found nothing. It must have been completely empty - because they did not say anything else for the rest of the night.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
I got away with one side poly engine mount on my LS1 cars. Most cause such an annoying NVH transfer, it's not worth going aftermarket. Unless you're racing a lot and breaking stock stuff.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
#7 | |
Moderator
#8 |
Did the car drive or go into gear hard when the mount started to go?
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
#9 |
didnt notice any vibration, but the noise did increase.
#10 |
![]() Drives: zl1 ABM A10 Join Date: Apr 2017
Hello night owl I know it’s an old post but hoping you’re still watching. I was launching this weekend and heard a noise in the floorboards like when you break open the park brake but louder and more pronounced. After that run I noticed a bit of oil like maybe the face of a dollar bill under the rear part of the motor. Made a couple more runs and didn’t really notice the clunk but this morning it is noticeable, especially when I leave a traffic light from a dead stop. When I tried to back onto my bendpak 4-post something was catching, so I checked and the drivers side catalytic conv was hooking on the crossmember. I’ve been on that lift 100x with no issue, only thing I can think of that would lower the geometry of the header would be the motor dropping eg. broken mount. I will put it in the air and check, but do u think that’s what it might be? I already have the BMR rear end and cradle lockouts so NVH is already piss poor ride after 80mph, so BMR poly is the way to go? Thank you !!!
#11 |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I installed mine with about 750 miles on the clock, I think I posted my feedback on another thread. These mounts not only made my headers super easy to install with all the extra space, but they seem to make the engine feel more responsive (more immediate connection power transfer). No noticeable vibration or negatives aside from them being tricky to install because removing the old ones sucks. Also I have had ZERO KR... which was my biggest concern. I would suggest every DIY owner to do these along with their header install.
#12 |
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
I recommend switching to BMR I switched when doing my headers and so much room.
