Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Best lights for garage....
Hey everyone looking to add some lights to brighten up my garage. All I currently have is the garage door opener light and would like to add some hanging lights and wanted to know what everyone’s suggestions are. Thanks for any help!
![]() Drives: '16 Z06 7 Spd, 2024 High Country HD Join Date: May 2015
Go to Home Depot, Lowes, Menards and get some 3-4 ft Integrated LED Strip Light. Bright, cheap, 29.95, no bulbs to break, last forever, can be chained together or separate pulls. I have them in garage, basement, re-loading area, etc. Take one home and try it. If you don't like it, return it.
![]() Drives: 2018 NFG ZL1-1LE Join Date: Jun 2018
I went with a bunch of 6” can lights with high wattage LED bulbs. 44 lights to be exact. This is while it was still under construction.
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Amazon Leonlite 40w LED lights. I have 4 in my garage and it is like daytime. 4 pack is less than $100. Easy install.
![]() Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
I got these ones. They are really easy to install. You can daisy chain them together too.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 1SS 1LE Join Date: Sep 2017
'18 1SS 1LE Black, PDR
#7 |
![]() Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
Make sure to check the light color temperature. You want something in the 4000k-5000k range to simulate daylight. Anything lower and you're going to have yellowish lights.
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
#8 |
![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
#9 | |
