Old 11-09-2020, 03:02 PM   #1
Aragorn
Drives: Camaro SS 1LE
Stock GYFS tires
Any reason why I should try a new tire brand?
No snow, very little rain, no track, weekend car only.
Thanks
Aragorn is offline   Reply With Quote
Old 11-09-2020, 03:42 PM   #2
camaroo
If your happy with your current setup, why change it? I personally am on the fence of switching them out for the sport 4s's, but that's because my car is more of a dd than it is a weekend car. If my car was strickly a weekend car, I'd keep the stock setup.
camaroo is offline   Reply With Quote
Old 11-09-2020, 03:58 PM   #3
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
I found the GY to be nice and sticky, but wore out completely in 10K miles. Ride on Ps4s is a bit better, definitely less (but not zero) tram-lining, and while the PS4 cost more, almost 2x more than some of the GY sales I've seen, should get enough tread-life to still come out far ahead with the Michelins.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 11-09-2020, 04:35 PM   #4
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
If you're not tracking it, the SC3s are a bit overkill and will wear out faster than other tires that will give an equivalent performance on the street like Mr. NoBrakes alluded to.
If you want to keep similar street performance then the PS4S is an excellent choice and $/mile you get out of tire wear should be better than stock. Getting an alignment check to make sure you're not wearing tires faster because of sometimes less-than-stellar factory alignment can help there as well.
If you don't drive hard on the street and want to even further maximize miles you get out of a set of tires, can look into some summer-oriented all seasons instead. I believe there's a few options out there for this as well that are usually cheaper than stock and should easily double the mileage you get out of a set of tires while still maintaining some aspect of performance. Might not be exactly factory size, but should be able to find them in either 1 step larger aspect ratios or slightly narrower or wider than stock.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 11-09-2020, 05:00 PM   #5
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i just got some put on my 1ss and went to the track yesterday dropped 6 seconds off from my last time out same track with michelin ps4s so i will be sticking with em fora while!
kropscamaro16 is online now   Reply With Quote
Old 11-09-2020, 05:22 PM   #6
JSH
JSH's Avatar
Drives: '20 ZLE
Put a set of 4S on my Camaro in September. I had used them on my two GTRs for years previously. The world's premier ultra performance (dry and wet but no snow) tire
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
JSH is online now   Reply With Quote
Old 11-09-2020, 05:38 PM   #7
kropscamaro16
i had almost 3 years on my ps4s and about 15k and about 5 track days on them
Old 11-09-2020, 05:56 PM   #8
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
It's hard to beat PS4S on the street. Vs GY SC3 you get a more comfortable ride, less tramlining, makes less noise, much better in the rain and will last at least 2x as long. Difference in performance is not a big deal on the street as the car is so capable anyways, the biggest difference is probably a softer or less sharp turn-in.
Old 11-09-2020, 06:56 PM   #9
JSH
JSH's Avatar
Drives: '20 ZLE
My stock 3R were so worn after 2000 miles and no track days I couldn't sell them
2020 ZL1LE A10.
Old 11-09-2020, 08:10 PM   #10
Aragorn
PS4S are expensive, wow!
Never really thought about all seasons for the desert, but they seem much more affordable. Discount tire has Bridgestone potenza for $242 w/ 50k mile warranty.
Got some some making to do.
Thanks everyone.
Old 11-09-2020, 08:15 PM   #11
BAUSS 1LE
BAUSS 1LE's Avatar
Drives: 19 SS 1LE
I just put another set of sc3's on but it is a track/weekend car. Only got 5,100 miles out of original set. I was looking for ps4s for daily wheels but was unable to get the fronts anywhere.
2019 SS 1LE Riverside Blue
BTR 225 cam, West Coast Cylinder Ported Heads, Kooks LTH with high flow cats, Lethal Garage flex fuel, LT2 ported IM, 95mm TB, Rotofab intake, AWE track, Mighty Mouse catch can, Eibach lowering springs.
Built by Red Barn Racing
BAUSS 1LE is offline   Reply With Quote
Old 11-09-2020, 08:26 PM   #12
DaveC113
DaveC113's Avatar
3Rs wear much faster vs regular SC3s. I got around 5k road miles + 10 AutoX events out of regular 3s.
Thanks everyone.
You won't get that warranty for a staggered setup. For Michelin it's cut in half, other brands I'm not sure.
Old 11-09-2020, 09:17 PM   #13
Aragorn
Dat gumit These darn sports cars!
Old 11-09-2020, 10:49 PM   #14
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
I am in the minority it seems, but I LOVE the SC3 tires. I also drive my car hard on the street though and I bought the 1LE to actually use what it is capable of.
They are cheap compared to the PS4, so IMO it is a win/win.
But as I said, I am a performance guy and actually drive my cars hard, as they were intended. 1.2 G's around cloverleafs is a great feeling and so is turning and burning up a mountain road.
But, that is me and I seem to be in the minority.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
