Old 11-09-2020, 12:44 PM   #1
Ox45
Hillbilly Highness
Drives: 2001 S10, 2022 LT1 Vert
2020 LT1 AFM Valve Question
I have a new 2020 LT1 A10 with about 700 miles on it. Yesterday I noticed that there was a random chirp while driving. Upon closer analysis it would appear that the chirp occurs only when changing from V4 to V8 mode.
After getting home and doing some reseach it appears that is the AFM exhaust valve. So here is my question..
Do I need to take it into the dealership immediately, or can it wait until I change the oil at 1,500 miles? Is it just an annoyance or can it cause other issues?
Also, I havent seen any posts about this that were recent. Is this common on newer A10 models?
Thanks all!
Ox.
Ox45 is offline   Reply With Quote
Old 11-09-2020, 05:36 PM   #2
njweatherman
Drives: 2018 Camaro 2SS, redline edition
It could actually be either the AFM valves, NPP valves and/or both. The AFM valves only open and close during the V8 to V4 transition. However, the NPP valves open and close at various times to muffle the sound. One way to isolate the problem is pull fuse 51 for the NPP valves. This will keep them open 24/7. If you still hear it when it goes from V8 to V4, then it is the AFM valves. You can eliminate the AFM valve sound by buying the range finder AFM disabler (https://www.rangetechnology.com/); however, you will have to wait because they do not make one yet for 2021 Camaros.
On my 2018 2ss Camaro, it ended up being both. So, I pulled fuse 51 and then bought the AFM disabler. All was quiet.
njweatherman is offline   Reply With Quote
Old 11-09-2020, 06:10 PM   #3
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
There are no changes between 20 and 21
lt4camaro is offline   Reply With Quote
Old 11-11-2020, 11:07 PM   #4
Lithias
Lithias's Avatar
Drives: 2019 2SS Riverside Blue Metallic
Hello!
Welcome to the squeaky valve club.
Helpful thread:
https://www.camaro6.com/forums/showthread.php?t=550172
I've also gone ahead attached the TSB for lubing the valves, Although I recommend if it is the NPP valves that you spray into the exhaust and make sure you exercise them a few times and spray in both open and closed positions.
I typically have to lube mine every couple months, not a very hard thing to do.
Order # WKXN0F 2SS Riverside Blue Metallic, A10, NPP, 56V
Ordered 9/15/18
1100......9/17/18
3000......9/19/18 TPW: 11/26/18
3300......11/9/18 TPW: 11/26/18
3400......11/12/18 TPW: 11/26/18
4300......11/22/18 BUILT! VIN: 1G1FH1R72K0123562
4B00......11/27/18 Waiting for Dispatch! Tentative delivery date of 12/11!
4300......11/28/18 Waiting for the train to Florida!
4200......12/5/18 SHIPPED!
4800......12/14/18
5000/6000......12/18/18 SHE'S HOME BOYS!
Follow me on Instagram! @the_3ngin33r
Lithias is offline   Reply With Quote
Old 11-12-2020, 04:13 PM   #5
Ox45
Hillbilly Highness
Thanks for the responses everyone!
I do not have the NPP exhaust on this car, just the A10.
What lube do you use? I saw the stuff they recommend in the TSB, but it doesn't seem so easy to find... unless I am missing something!
Thanks again,
Ox.
Old 11-12-2020, 05:38 PM   #6
grampa_ss
grampa_ss's Avatar
Thanks again,
Ox.
https://www.amazon.com/ACDelco-10-40...s%2C207&sr=8-4
Old 11-12-2020, 05:52 PM   #7
Ox45
Hillbilly Highness
Nice... Thanks!
In the description it says that it is discontinued by mfg. Is there a replacement part # or is that prolly a misprint? Either way... Looks like it is in stock now! 😀
