![]() Drives: A customized 2016 and original 1969 Join Date: Jun 2016
Good rotor options for zl1s?
Hey I am looking into some new rotors for my zl1- I know that the brembos on the cars are good but I’m looking for slotted/drilled. Has anyone used R1 Concepts or have any reviews on those? Or have any other suggestions? I typically just use my car for street use not doing track right now- if I do I’ll switch stuff out so I just need good street brakes.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Really wish these guys made something for the ZL1. I had a set on my Hellcat. Nice weight savings and a better quality rotor.
https://www.girodisc.com/ The front rotors are 24.4 lbs vs. 31 lbs for the stock Hellcat 2 piece units. The rear rotors are 18.9 lbs vs. 24 lbs for the stock units. |
#3 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
They have them.. https://www.girodisc.com/Girodisc-Fr...L1_p_6826.html A1-211 Front A2-211 Rear |
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
I've been contemplating getting them for my Hellcat for a year now.
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
#5 | |
would be a waste of money.
#6 | |
#7 | |
A good bit lighter and its unsprung weight so thats the most effective weight to take off. They're also built better than the factory Brembo rotors which are known to warp and/or develop hot spots after 20-30k miles. |
#8 |
![]() Drives: '18 ZL1 1LE Join Date: May 2020
They don't show up if you use their normal make/model layout. BUT, if you type "6th gen camaro" in the search box both sets front/rear come up. They are $550 per rotor front or back.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
#9 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
How much are the replacement rotors, once you have the girodisc hats?
Baby Blue
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
girodisc or dba is what most guys run with!
#11 |
One forewarning, the front Girodisc rotors don’t use the same pad shape as OEM they cut the pad for a bit more radial depth as the hat is a larger diameter. The closest pad shape that is mass manufactured is the SS 1LE but it doesn’t perfectly cover the rotor a little bit of rotor face is left exposed near the hat. Check out the videos by KNS Brake and you’ll see what I’m referring too.
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
#12 |
![]() Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10 Join Date: Dec 2017
since OEM pads can not be used with girodisk rotors - does anyone know what size pads are needed? e.g. is it the SS 1 LE pad size? i am asking to see if this option help improve the pad selection available....
#13 |
The SS 1LE pad size is near perfect just a couple mm of rotor space being unused, but it’s the best pad shape that’s largely produced as for a perfect fit requires a custom pad shape.
#14 |
Who Needs to KNOW?
There was another thread discussing this (https://www.camaro6.com/forums/showt...=563737&page=4) - moral of thread: OEM brembo rotors are best for durability and longevity. DBA and gerodisc, too many compromises to be any better given they are comparable or higher than OEM in cost.
