Old 11-06-2020, 04:08 PM   #1
1ssa_camaro
Drives: 2017 Camaro 1ss A8
Do Long tube headers cause cabin noise?
Hey guys, do your guys headers make noise inside the cabin? I’m not talking about drone, but like a ticking sound when you’re cruising at normal speeds? I have the A8. Wondering if I have an exhaust leak. I can hear it with the windows down, and it’s more noticeable in the driver side. I’ve had the headers on for 5 months now, and I’ve noticed the ticking has gotten louder? Any ideas? Thank you
1ssa_camaro is offline   Reply With Quote
Old 11-06-2020, 04:11 PM   #2
1ssa_camaro
*With the windows up*
Old 11-06-2020, 04:26 PM   #3
JasonGofast
Used to own a ZL1
Drives: '16 Z06
You sure it's not just the direct injection? I'd imagine the headers would amplify that sound greatly.
JasonGofast is offline   Reply With Quote
Old 11-06-2020, 05:09 PM   #4
scantone
Drives: 18 Z1E - 18 Raptor - 17 Jeep SRT
Headers will make additional noise. When I wrapped mine it cut the noise down substantially.
scantone is offline   Reply With Quote
Old 11-06-2020, 05:57 PM   #5
Altered Carbon
Ghost Spawn
Altered Carbon's Avatar
Drives: Camaro
It's probably an exhaust leak if it has become increasingly and noticeably louder since the install. If it's barely louder, it's most likely normal.
Altered Carbon is offline   Reply With Quote
Old 11-06-2020, 06:11 PM   #6
1ssa_camaro
Will the exhaust leak cause a CEL or cause the car to lose performance? And if it is a leak, will the headers need to be removed completely?
Old 11-06-2020, 06:14 PM   #7
1ssa_camaro
I know the headers will become a bit loose overtime since the engine moves and stuff like that, but not sure if it’s just the direct injection noise or an actual exhaust leak. A reputable shop in my area installed The headers and Tuned the car. it made the same ticking sound The same day I picked up the car with the tune and headers installed and my tuner did not mention it or anything so I assumed it was normal. So now debating if it’s just the DI sound or an actual exhaust leak, or a lifter failure :(
Old 11-06-2020, 06:16 PM   #8
s346k
s346k's Avatar
Drives: like an old lady
i'm going to say it's di stuff. mine was/is the same way. it has seen a lot of abuse and 7k rpm several times since then.
Old 11-06-2020, 08:40 PM   #9
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
I hope its not the dreaded lifter issue.. My long tubes didnt add ticking noise, but the normal engines noises are very ticky.. I heard something new a couple weeks back - and she is in the shop.
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms.
Homer2 is offline   Reply With Quote
Old 11-07-2020, 09:44 AM   #10
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
I have had the same issue, I thought I did and still do have an exhaust leak. I took it to an exhaust shop that was too busy too look at it, but they said at least with kooks ball and socket type connections leak alot. So I went under my car that weekend and I can't find any dark spots are soot around any of the connection points. It may be just the headers allowing sound to pass I guess. But I hear it under the the driver side side floor board, not a rattle like metal on metal, but maybe keys jingling together or a ticking sound.
Old 11-07-2020, 10:31 AM   #11
1ssa_camaro
Yea bro, and you’d imagine that $2,000 long tubes would be flawless, but I have seen your posts a while back and still see you’re still going through that exhaust leak issue. I have speed engineering headers myself. Being in California, I know someone that has a connection at speed engineering and he was able to get me a pair with the long tubes and x pipe for $600, and honestly can’t complain. Good quality. Got these in June when they were all sold out too, and I think they’re still on back order.
Old 11-07-2020, 10:53 AM   #12
gtfoxy
Drives: '21 Wild Cherry ZL1
You can get a mechanic stethoscope, or make your own, I prefer to make my own out of 3/16 or 1/4 brake line & hose, you just put the hose on your earlobe & press it into your ear, & while it’s running listen around every joint circumferentially. If there is a leak it will sound like a whooshing noise.
You can also listen to each individual pipe to see if your ticking becomes louder in time with what you are hearing.
