Old 11-06-2020, 03:53 PM   #1
fuzzum111
Drives: 2018 Rs Camaro
*UPDATE* Supercharged LGX new Dyno figures, and questions about the 8Spd Trans
Hey guys, it's been a moment or two.
I haven't updated everyone on what's been going on, as well, not a lot had happened due to covid.
As a quick recap, I bought the Edelbrock 1.7L roots supercharger for my LGX Camaro. It came stock with a 6lb 3.5" pully. I got about 80ish WHP from it going from 260WHP to 340ish WHP.
I wasn't very happy with their extremely fat tune, and my pipes were being blackened by the amount of unburnt fuel. That said, the performance increase was significant, and the physical equipment was quality stuff.
So I bought an 3.25", 8lb pully, and had my shop retune the car. They wanted to push for more, but due to spark knock, they had to take timing out and we ended around 353WHP. Another small increase, while they told me "You need to go to these cattless downpipes, the engine is being choked. This will fix a lot of your issues."
Soooo, I waited on that. Until I realized the other possible problem they warned me about manifested and "forced" my hand, I started to blow my cats out. I bought the American Racing Headers, 2016-2020+ Catless downpipes. I got those installed, and they re-tuned the car and I got another solid 30WHP. I went from 353WHP to 383WHP, and it's still a very conservative tune.
It pulls really hard now, if it doesn't spin the tires. The only "worry" I have is it will slip the clutch really hard between 1st and 2nd when WOT sometimes. Or when rolling into the throttle and shifting it'll so something similar.
There aren't many options to fix this, and I don't think spending $800 on "transmission tuning." will fix that, will it? I probably need to upgrade the internals, or swap to a heavier duty transmission? Unless it is rated for the same load the SS made, and just needs to be tuned to expect that power?
Here is a video, it doesn't show the slipping but it does show the acceleration. Make sure to turn the sound on.
https://gfycat.com/spiffyuntriedappaloosa
fuzzum111 is offline   Reply With Quote
Old 11-06-2020, 03:56 PM   #2
fuzzum111
Crap, realized I posted this in the wrong section. Probably needed to post this in the forced induction section?
My primary goal here is asking if the Trans tuning that is being offered, would make a difference in my transmissions ability to cope with the significant increase in power?
Old 11-06-2020, 03:56 PM   #3
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
Very nice. So you're running about 8 psi on 93 octane?
HCI2000SS is offline   Reply With Quote
Old 11-06-2020, 04:02 PM   #4
fuzzum111
We only have up to 92 here, but yes. With the downpipes they're able to do a whole bunch more.
I'd like to push to 10 or 12lbs and get up to around 425WHP, but with the integrated headers, I'm not sure how much more I can really do with this engine without E85 or Meth spray.
Old 11-06-2020, 05:11 PM   #5
HCI2000SS
HCI2000SS's Avatar
Good deal. Those numbers are right there with a stock LT1
Old 11-10-2020, 03:26 AM   #6
Kairles
Kairles's Avatar
Drives: 2015 Camaro 1SS
Even got a little blower wine, nice.
Kairles is offline   Reply With Quote
Old 11-15-2020, 01:49 AM   #7
fuzzum111
So the question begs
How do I deal with the transmission slipping?
If I do a manual mode, WOT pull from a dig, if I shift at 7k, it'll slip real bad into 2nd, and then I'll early shift into 3rd to deal with it.
Will a "Trans tune" help this, do I just need to check the fluids? Is there any mechanical upgrades I can do to it, or is a trans swap(to like the current 10spd) the only viable solution?
Old 11-15-2020, 05:00 AM   #8
Kairles
Kairles's Avatar
I'd start with a tune, at the least it should help with the slip. Looks like the gearbox is rated at 400 lb-ft and looking at your WHP I'm sure your close to that. That's what sucks about the non V8 Camaro's. The torque that the rest of the drivetrain can handle is barely more that the engine's produce stock.
Old 11-24-2020, 05:50 PM   #9
fuzzum111
Here's a video with a cold start with the new pipes.
https://youtu.be/Hongl8yNH3k
Old 11-24-2020, 05:53 PM   #10
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
With a trans tune you should be able to up the line pressure at WOT shift, which should help eliminate slippage.
Old 11-24-2020, 06:03 PM   #11
HCI2000SS
HCI2000SS's Avatar
On the topic of the transmission, I take it you had the latest fluid and flush procedure done?
Old 11-24-2020, 06:36 PM   #12
fuzzum111
I'll have to go to my service center and find out and schedule one if one hasn't been done yet.
Old 11-24-2020, 06:43 PM   #13
HCI2000SS
HCI2000SS's Avatar
Reason I ask that is because if it hasn't been done that could be part of the problem. If not caught in time it will damage the torque converter and that's obviously not good
Old 11-24-2020, 07:21 PM   #14
dgriff14
waddupdgriff
dgriff14's Avatar
Drives: Supercharged 2016 2LT RS
Same! Had mine since December, I got a post or two floating in this sub about it.
Another friend of mine did similar to you but went down to a 3 inch. I’m gonna be a little more conservative and do a 3.25 inch myself.
Did you swap the pulley and belt or the shop did that as well? Hoping to see what I’m about to get into lol
2016 Chevrolet Camaro 2LT RS
• Edelbrock E-Force Stage 1 Supercharger • Custom tune by Overkill Motorsports • AFE Momentum GT Pro Dry Cold Air Intake • MBRP SS Cat Back Exhaust • iROC-z Wheels • Nitto NT555 G2 Tires (275 fronts, 305 rears)
dgriff14 is offline   Reply With Quote
