Old 11-05-2020, 12:38 PM   #1
Smoke-in
Drives: 2018 Camaro SS 1LE
Camaro gas tank drane
2018 Camaro SS is disabled for a while until I get my new half shafts installed. Is there any easy way of draining 3/4 tank of E-85?? short of dropping the tanks.
Smoke-in is offline   Reply With Quote
Old 11-09-2020, 02:40 PM   #2
Petrol Head
Drives: Fast if no one's looking
I would just pour some Sta-bil fuel stabilizer in there if it's going to be parked for a while.
Petrol Head is offline   Reply With Quote
Old 11-09-2020, 03:55 PM   #3
laynlo15
Drives: 2022 Lt1 A10
Just fill it up with 93 octane, that will probably take care of it. What percentage are you at now?
Old 11-09-2020, 08:21 PM   #4
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
Drain. Disconnect from the rails and empty into a container using the intank pump.
ssmofo is offline   Reply With Quote
Old 11-09-2020, 08:48 PM   #5
mikeman
Drives: 2015 Camaro
Are you sure that's a good idea at the pressure direct injection runs at?
mikeman is offline   Reply With Quote
Old 11-09-2020, 11:13 PM   #6
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
Pretty sure the tank pump is the low pressure pump and I believe there is a cam driven high pressure pump on the DI engines. I read that somewhere or somebody whispered it to me while I was sleeping.
ariZona28 is offline   Reply With Quote
Old 11-09-2020, 11:53 PM   #7
mikeman
Drives: 2015 Camaro
Got it, thanks. I wasn't sure how the low pressure and high pressure stuff worked on these cars.
Old 11-10-2020, 09:48 AM   #8
Smoke-in
Yeah, the pump is the low side, you must run the engine to get it from the rails.
I got about a half tank E 85 right now. I will see the new half shafts in two weeks, so I just may throw in some stabil and bite the bullet!
Old 11-11-2020, 02:18 AM   #9
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
im not sure about this but i believe you have to jump the fuel pump to get it to drain the tank. It sees that its not getting up to pressure so the ecu shuts off the pump because it thinks there is a leak. not sure though.
