![]() Drives: 2018 ZL1 Join Date: Oct 2020
New ZL1 owner
Hi Forum,
Just picked up a used ZL1 that I've been enjoying since Sunday. It appears to be more capable then the 2009 Corolla I drove for the last 10 years to save money for the kids. The only thing I've run into so far is that I have a short but steep driveway. When I turn into the driveway at an angle to avoid scraping, one of the rear tires comes off the ground. I keep leaving little mini burnout marks. Does anyone know of a better way? Also, feel free to please share any advice for things I should be doing regarding service (Currently @ 14k miles). I look forward to contributing to this forum someday as I gain more experience with the car. Thank you! |
#2 | |
![]() Drives: women crazy Join Date: Aug 2020
I don't really understand the mini-burnout situation.
‘19 1SS A10, Borla S-type Non-NPP-SOLD
Reznap, it's hard to tell if you're joking with that "appears to be more capable" (under)statement, but one thing's sure, you've invited some roasting, whether or not you meant to
Congratulations on the car, it's an amazing beast ![]() As to your driveway, try tour or snow mode and less throttle input. The chassis is (fortunately) very rigid and it's quite possible that you would lift a wheel in that situation.
![]() Drives: Black 2019 ZL1 M6, Join Date: Sep 2019
look for driveway curb risers. It may help with the approach angle on the driveway so your dont raise the rear tire during transition.
https://www.google.com/search?q=driv..._AUoAXoECAQQAw
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
![]() Drives: 2019 ZL1 Join Date: Jan 2014
Happens to me sometimes too. I find its better to roll through it slowly rather than stop and start again.
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
I have a pretty steep driveway as well.
I knew it was gong to be a concern when I built the house so I made sure the approach angle was a certain angle for a certain distance then increased at a certain rate. I still have to come in at an angle, but I have yet to rub on mine. It requires me to use 3/4 of the road coming from one direction, but it works. I like the curb riser idea. That’s pretty cool. Add: Congrats!
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Curb rise looks promising
#8 |
![]() ![]() ![]() Drives: No Camaro :( Join Date: Apr 2013
That’s a big step up in power! Congrats!
#9 |
Yes, a real mystery.
#10 |
He has 4 posts and I've learned to assume absolutely nothing...
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Yep, curb risers. The chassis on these cars is insanely stiff.
#12 |
![]() Drives: ‘18 Camaro ZL1, ‘16 F150 S/C Coyote Join Date: Sep 2020
Had mine 2 months now...I have the same problem going into my driveway. The tire chirp is just my way of saying I am home.
#13 |
Thanks for the welcomes!
Yes I would say its a nice change of pace compared to the Corolla .I will try the snow/ice/touring mode for the driveway as I've mostly been in sport. Is there a write up anywhere that explains each mode in more depth, aka "track mode gives you 30% slip angle before reigning you in."? |
#14 |
![]() ![]() ![]() Drives: 2019 CLA 450 Mercedes Join Date: May 2016
https://www.bridjit.com/
These folks can fix you right up. I have 5 sections in my drive. These are super sturdy. Mine are over 5 years old. They will do a Google Earth to look at your house, if you call them on the phone.
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red 2014 Lincoln MKT EcoBoost (The Bus) |
