Old 11-03-2020, 12:01 PM   #1
NiteBlitz
Drives: Camaro ZL1
Code P012B just came up
P012B Turbo/Supercharger Inlet Pressure Sensor Range
Read more at: https://www.obd-codes.com/p012b
Copyright OBD-Codes.com
Looked it up. Other then the info the website above provides any one have the same issue or possible fixes?
Car seems to be running fine. Code just appeared after normal driving. Car has been modded. Headers were done about 2 to 3 months ago. No issues until now.
NiteBlitz is offline   Reply With Quote
Old 11-03-2020, 12:19 PM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Bad tune? (upper range limit not increased from pulley change?)
or
Bypass valve stuck?
"The code sets when the manifold absolute pressure sensor (MAP) detects pressure outside an acceptable value. The book shows that P012B can be caused by a slow MAP sensor or a damaged MAP sensor."
Old 11-04-2020, 10:14 AM   #3
NiteBlitz
Drives: Camaro ZL1
or
Bypass valve stuck?
Would a bad tune take a few months for light to come on? Going to replace the sensors and see what happens.
Old 11-04-2020, 02:15 PM   #4
Gunkk
Gunkk's Avatar
Probably not. But ambient temps have been lower in the last week so if it was right on the edge and we get a mineshaft air day or two...
Could just be the MAP sensor going bad, loose connection, etc.
Old 11-04-2020, 02:41 PM   #5
JSH
JSH's Avatar
Drives: '20 ZLE
You should log the data to see if it's lean or has any negative advance. Can't comment further w/o seeing all your mods
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 11-04-2020, 02:43 PM   #6
JSH
JSH's Avatar
Drives: '20 ZLE
You should log the data at WOT in 3rd gear to see if it's lean or has any negative advance. Can't comment further w/o seeing all your mods and tune
2020 ZL1LE A10.
Old 11-05-2020, 01:15 PM   #7
NiteBlitz
Drives: Camaro ZL1
Full list of mods include e85 sensor, upper pully, headers, cold air intake.
What should I look for logging. I have one of those bluedriver obd2 devices that provides data.
Old 11-05-2020, 03:25 PM   #8
JSH
JSH's Avatar
Drives: '20 ZLE
Let's start by finding the Dynamic Advance data column and looking for any negative numbers (meaning it's pulling timing)
I'm new to the LT4 supercharger but it must have some type of wastegate, so look for WG "%" column
Also, pull and clean MAF sensor, then disconnect battery + lead to reset ECU.
2020 ZL1LE A10.
Old 11-05-2020, 05:37 PM   #9
zincgt
zincgt's Avatar
Drives: 2017 A10 ZL1
I had the same code at one point and I forgot to tighten the bolt for the sensor when I did the upper pulley. Its behind the TB to the right, 10mm bolt.
zincgt is offline   Reply With Quote
Old 11-06-2020, 02:21 PM   #10
NiteBlitz
Drives: Camaro ZL1
I said **** with it and just took it to the mechanic/tuner. We replaced the sensor with new one from dealer, bout $50.00. Code did not go away. He plugged in his laptop and was able to clear it.
