Old 11-02-2020, 07:44 PM   #1
JRS
JRS's Avatar
Drives: 16 camaro M6/ 18 ZL1 camaro A10
Keyed hot in under hood fuse box?
Is there any keyed hot fuses in the under hood fuse box? I don't really want to splice any wires but I didn't see any.
JRS is offline   Reply With Quote
Old 11-03-2020, 01:05 AM   #2
puppykat33
puppykat33's Avatar
Drives: Black 2019 ZL1 M6,
assuming you mean a switched 12v power supply? what are you trying to power? depending on what you are doing there are several options. there is a switched power wire on the interior that the wireless charging pad runs on. there are switched fuses in the trunk fuse box. just depends where and what your are trying to accomplish. details my friend the devil is in the details...
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
puppykat33 is offline   Reply With Quote
Old 11-04-2020, 06:05 AM   #3
JRS
JRS's Avatar
I'm looking to power my methanol relay switch so it doesn't need many amps but I wanted to keep it hidden by using the fuse box under the hood.
Old 11-05-2020, 01:14 PM   #4
ThePeoplesCamaro
Patriot
ThePeoplesCamaro's Avatar
Drives: 2019 Camaro 1SS 1LE
I just cut out my cig lighter and ran a wire from there through the sound tube hole for all my electronics. Replaced the cig lighter with a switch for the two step
2019 Camaro SS 1LE M6, Ported LT2 Manifold w/ 95mm TB, Flex fuel, Kooks Longtubes catless to NPP, Big Gulp intake, TSP EL-C7 cam w/ Titanium valves and dual Springs, 605HP at the tire N/A
ThePeoplesCamaro is offline   Reply With Quote
Old 11-06-2020, 01:19 AM   #5
GroundhogSS
GroundhogSS's Avatar
Behind the fuse box under the cover where the positive terminal is, is a buss bar with hot connections. Apparently on some models, the base plate is hot but the threaded posts are not. I have several items connected there. Pull out and up on the ends of the cover.
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 11-07-2020, 10:45 AM   #6
NowaChevyGuy
NowaChevyGuy's Avatar
Drives: 2016 Camaro LT1 RS Black on Black
That is some badass engineering right there. Super clean!! 👍
NowAChevyGuy
2016 RS - Trifecta Tuned, 3.23 diff swap, Borla S Type, JMS Throttle Controller, Lambo doors, Monster stereo, GM LED rear tail lights, BMR swaybars/End Links/Trailing Arms, tinted dark and murdered out.[/br]
Car kicks ass! $20k.. and I get 20mpg with my foot in it, everywhere I go!.... Say somethin about V6's now...
NowaChevyGuy is offline   Reply With Quote
Old 11-08-2020, 01:56 PM   #7
JRS
JRS's Avatar
Thanks for the replies! This helps give me some ideas as to what I can do.
