Old 11-02-2020, 03:32 PM   #1
meSSohappy
meSSohappy's Avatar
Drives: 2018 ZL1 A10
2018 and 2021 ZL1 differences
Other than tail lights and rear view mirror camera, are there any other differences between the '18 and '21 ZL1's? Considering trading/selling mine for a vert.
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
meSSohappy is offline   Reply With Quote
Old 11-02-2020, 03:52 PM   #2
Vigilante375
Drives: 2018 Camaro ZL1
The convertible ZL1 does not get the eLSD (it gets a regular limited slip diff), no PTM (performance traction management) and smaller anti roll bars. I think the performance data recorder isn't available for the convertible.
Old 11-02-2020, 04:19 PM   #3
ZLE dude
Drives: '18 ZL1 1LE
No homelink (garage door opener) in the 2021.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 11-05-2020, 05:02 AM   #4
Getnlwr
Drives: '21 ZL1 A10 '08 SRT10
Wow. They take away a lot of good stuff from the car.
Getnlwr is offline   Reply With Quote
Old 11-05-2020, 06:55 AM   #5
Noreplacement
Noreplacement's Avatar
Drives: 2018 ZL1 Vert
Chassis is stiff, no cowl shake and hugely capable performance.
95% + performance of the coupe. Open air driving experience is what I wanted.
Hard to fault the vert. Lots if grins.
Can't go wrong.
Noreplacement is offline   Reply With Quote
Old 11-05-2020, 07:10 AM   #6
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Correct. No PDR in the vert.
Say it with me: "Six-Hundred Fifty Horsepower Convertible"
Old 11-05-2020, 08:02 AM   #7
gtfoxy
Drives: '21 Wild Cherry ZL1
Didn’t know that.
Old 11-05-2020, 08:42 AM   #8
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
I believe that the rear stabilizer is different and the front is the standard FE4, ZL1 stabilizer bar.
The ELSD adds weight, complexity, as well as size that cannot reasonably be fit under cross bracing, so that was eliminated. Unless you’re racing, you’ll never notice not having it. The vert diff does have a heat exchanger.
The 2019 and up verts - rear view camera. The one down side is if you want to keep the camera and change the spoiler. I haven’t found a reasonable way to do this (yet).
Old 11-05-2020, 09:23 AM   #9
Vigilante375
Either way. Still a capable and fast convertible.
Old 11-05-2020, 10:05 AM   #10
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
A10 trans is not able to be tuned on the 2020+.
Old 11-05-2020, 10:26 AM   #11
Z OH 6
Drives: 2021 Red Hot ZL1
This is true, but according to Vengeance Racing, the stock trans tuning is just fine until about 1000HP.
Old 11-05-2020, 10:35 AM   #12
KingLT1
KingLT1's Avatar
That is a blanket statement at best.
Old 11-05-2020, 10:44 AM   #13
Z OH 6
Fair enough, what do they know?
Old 11-05-2020, 11:06 AM   #14
KingLT1
KingLT1's Avatar
Here are some examples that might help you understand why I said what I did.
If you switch to a larger camshaft which normally shifts the power curve to the right, Ideally you want to bump up the shift points to utilize the increased power range and maximize the cams potential. Also depending on camshaft selection, it may require a higher stall converter. Different power adders benefit from higher stall converters such as F1a94 prochargers which seems to be a popular option on this platform. All scenarios I have pointed out here would require transmission tuning to maximize their potential. Does that mean you have to...NO. I am sure there are packages designed to work around the parameters of the stock transmission tuning but it doesn't really have anything to do with a power number alone. There is more to going fast then a power number.
