![]() ![]() Drives: 2018 SS 1LE Join Date: Apr 2017
Is the Mustang going back to pushrod?
![]() Drives: BVM 1SS Join Date: Oct 2016
Finally we can lay the "BuT The MUStanG oNLY HAS FiVe LETeRs hurr durr" trend to bed
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Seems like a stretch, given their Ecoboost and downsizing trend.
But at the same time, they are slowly canning the Coyote on F150 and pushing hard on the Ecoboost 3.6, so it's possible that they are using another V8 so they have a V8 Mustang option.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
2020 Shadow Gray 2SS
What is the benefit of a pushrod motor vs. an overhead cam motor? Seems like a step backwards (although I'm not that well versed on this so I might be way off)...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#5 | |
The only real disadvantage is that they can't rev very high because of the extra mechanical coupling (pushrods), everything else is negative hype.
#6 | ||
But yeah, pushrod engines still exist for a reason. Here is an Engineering Explained video for a quick summary:
Current:
#7 |
![]() Drives: 2023 Camaro ZL1 Join Date: Jan 2016
I hope ford does it and forces gm to put the LT3 into production for the camaro.
#8 |
Thank you Al Oppenheiser!
DOHC engines are expensive to make and top-heavy.
The timing chain kit gets very big and complex and the heads are huge with nearly 2x the moving parts. |
#9 |
#10 |
![]() Drives: 2019 1ss 1le, blue wrap Join Date: Aug 2017
That’s a good video... how do nascar engines rev so high? I think 9k if I remember
#11 |
#12 |
To be devil's advocate for a second, GM themself has made and is making DOHC V8s. Remember the Northstar? Supposedly a pretty solid engine with the correct head bolts. Now we have the Blackwing 4.2TT which looks pretty awesome as well.
When you don't have to have the engine last hundreds of thousands of miles, be daily-friendly, and the budget isn't an issue, anything is possible.
Current:
#13 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Lubrication is also another challenge with DOHC engines.
#14 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
Coyote engines are garbage anyway. They're tapped out as far as power and reliability. Ford would have to up the displacement again and even then they'll be sacrificing reliability. Look at the Doodoo engine. That thing was swamped with issues at 526 HP. Meanwhile both GM and Dodge at 6.2 and 6.4 respectively are easily in the upper 400 HP range without any of those issues. And they could still go higher in HP or increase displacement. I doubt Ford can push past 480 HP on a non-special edition non-limited production Mustang and get away with it. They'll be blowing up left and right worse than the GT350s did.
