![]() Drives: 2019 Camaro 2SS A10 Join Date: Oct 2020
Stage 1 cam options?
Hello, I'm looking to potentially do a cam swap. However I'm big on daily drivability, therefore don't want to sacrifice reliability or a lot of low end torque for city driving. Would a stage 1 cam be a good option, that still provides enough gains to warrant the expense? If so, what are some of the best options on the market?
Normally I'd do my own research on this but, cams seem to be the one part where there isn't a lot of available data or dyno information so, I'm pretty clueless. Thanks! |
![]() ![]() ![]() Drives: 2020 LT1 M6 Join Date: Jan 2016
"provides enough gains to warrant the expense"
This is something that is highly subjective. A cam swap alone with no head porting won't yield much power, much less a "mild" daily driver cam that will live in harmony with your factory valverain. As for specs and manners, I'd imagine something grinded along the lines of a stock LS7 would give you a small power bump and be plenty mild. Duration @ .050 in. (int./exh.)210°/230°Valve Lift0.593 in./0.589 inLobe Separation120°Cam Advance-3 degrees Again keep in mind that without head porting and at least a factory lt2 intake, a mild cam won't do much, it's a $5K+ job on these motors, unless you are doing all the work yourself. |
#3 | |
This will not just be a cam on a stock car. It will be a cam on an E85 tuned SS with ported LT2 manifolds, 1 7/8 catless long tube headers, 95mm ported TV, Rotofab, and if I can find someone who'll do the porting for a reasonable price, ported heads. I am assuming these mods give me more to gain with a cam upgrade? |
#4 | |
Great to hear, that's basically the goal while I'm still NA. Do you have a ballpark idea of how much of that power is coming from the cam?
30 to 35 to the wheels, if garnished by the the complimentary mods you stated. Should be 100 whp package all motor if you shop and tune accordingly.
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: E92 BMW M3 Join Date: Oct 2012
I like your build goals OP, exactly what I want to accomplish just not sure how big of a cam I can get and I also dont want any major chop....just a slightly lumpy idle. I plan to go custom, and work with Pat G again probably.
J-Rod Built and Matt@FSP Tuned |
#8 |
I would go with a Cam motion Titan 1 218/228 .594 .585 114+5 or the Titan 2 222/234 .612 .603 114+4 and have Pray do the tuning remotely. The Titan 1 will have a very mild idle, work with factory headers, converter, and intake manifold. The Titan 2 is borderline of needing Long tube headers, stall, and at least a LT2 IM but it would still work ok with the stock stall. Any larger(stage 3+) then ideally you need ported heads, 3600 stall, and a ported MSD at minimum, and Long tube headers to take full advantage of the extended RPM range of the cam.
Even with the stage 1 I would probably still opt to port the heads, longtube headers (or cat delete pipes with stock headers at minimum), and a LT2 IM.
#9 |
![]() ![]() Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
The GPI stage 1 is also a nice option
Ported intake manifold and throttle body kooks 2" headers no cats
#10 | |
![]() Drives: 2018 1SS M6 Join Date: Feb 2018
2018 1SS M6 - OTR intake, HI Ram intake, Ceramic Coated TSP Headers Catless, AWE Touring Axle-Back, Flex Fuel, Pray Performace stage 3 cam, TSP ported heads, Pray Ported 95MM TB and Ported HI-RAM. SJM Line-Lock. F14 Drag Pack 17's with front skinnies. Tuned by Pray Performance.
#11 |
You can make some excellent gains with just a cam and bolt ons. With E85 you should be over 500 even with a small cam. Tuning is important but the rule of thumb is don't go with to much cam for the stock converter. Most stage 1 cams are designed to rock the stock converter. After that a stall speed is recommended. Check out the GPI stage 1 cam, we've done that a bunch and had some great results for both power and drivability.
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
Like others have said, the tuner makes a big difference and it seems the right tuners are making big stage 3 cams drive great with the gen 5 DI engines.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
