Old 10-25-2020, 11:40 PM   #1
1ssa_camaro
Drives: 2017 Camaro 1ss A8
A8 shudder
Hey guys my car has had the A8 shudder for a while. I currently have long tube headers, e85, and intake with a tune. Will the dealer void my shudder fix? It doesn’t really bother me, but was wondering if it can be harmful to my transmission or if it can affect the cars performance? If it does, I’ll just take it to the dealer and get it fixed.
1ssa_camaro is offline   Reply With Quote
Old 10-26-2020, 01:26 AM   #2
Azerlazer26
Azerlazer26's Avatar
Drives: 2018 Camaro 2SS
To be honest it really comes down to the dealership. I know of some who will straight up refuse any warranty work because you have a simple mod. In general, you should be ok and have 0 issues with getting a warranty claim.
As far as the shudder goes, it can cause damage to your torque converter. If it’s damaged enough the dealer will replace the TQ/Fluid. Most cases the fluid flush does the trick.
Azerlazer26 is offline   Reply With Quote
Old 10-26-2020, 03:09 AM   #3
Puddin
Just get an aftermarket converter and be done with it.
Old 10-26-2020, 08:08 AM   #4
Memphis SS
Memphis SS's Avatar
Drives: 2017 SS A8 Hyper Blue/White Stripes
Converter alone will not fix the issue, the trans needs the correct fluid. Go by the dealer and just ask your service writer to check the issues and provide the service bulletin. Tell him you’re only approving warranty work to call if any additional repairs are needed and let them find the mods and see if they think it voids the warranty service.
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD
Memphis SS is offline   Reply With Quote
Old 10-26-2020, 09:28 AM   #5
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
You had the shudder before you did all the mods or after? I assume it's tuned as well?
HCI2000SS is offline   Reply With Quote
Old 10-26-2020, 02:21 PM   #6
1ssa_camaro
I’ve had it before the mods. It’s still the same. I’ve had it around 8k miles, I’m at 13k now, and It hasn’t felt worse. Feels the same. I’m only caring about it now because I want to know if it can affect the cars performance
Old 10-26-2020, 02:56 PM   #7
ctrlz
There is a very specific procedure for the dealer to follow. I posted a link to it in another thread. You complain about the shudder, then they use special equipment to detect vibration at a specific frequency under road test conditions to confirm the TC is the source of the problem. Your mods should have no effect.
I would print out the TSB and show the dealer.
As others have reported, the shudder does not go away or get better. More likely it will permanently damage the clutches in your converter.
I think people get hung up on the idea that it is fluid that is defective, and therefore must not be a big deal.
Old 10-26-2020, 05:18 PM   #8
Trochoidal
Drives: 2017 Camaro 2SS A8
If they don’t honor the TSB under warranty because of mods, I’d suggest to pay for the service or change fluid yourself. It would probably take 3 fluid changes if you did it yourself. At $10 per quart, filter and gasket it might be cheaper for them to do the flush.
24 quarts of fluid (Mobil 1 124715 Synthetic LV ATF HP) @ $10 = $240
3 filters (TF922) @ $24 each = $72
3 gaskets (24260071) @ $27 each = $81
$393 total
Old 10-26-2020, 06:08 PM   #9
ItsChristianInHD
ItsChristianInHD's Avatar
Drives: 2017 Camaro 2LT RS 3.6L
It depends if you have a cool dealership or friends that work there. I have friends at dealerships and that’s how I got lucky.
ItsChristianInHD is offline   Reply With Quote
Old 10-26-2020, 09:51 PM   #10
Your strategy is going to backfire, once the shudder gets tangibly worse, most of the friction material will have eroded from your torque converter clutches and you'll have a harder time getting the converter replaced under warranty. Go get the flush done ASAP.
+1
Here is the TSB: https://static.nhtsa.gov/odi/tsbs/20...63890-9999.pdf. This latest edition specifically states that no validation beyond the customer complaint is required, ie the dealership should do it and be able to get reimbursed by GM because you say so.
One final note, the A8 without the shudder (and especially when tuned) is a fine transmission, it's worth the mild hassle of working with the service department or finding a good one.
Old 10-26-2020, 11:35 PM   #11
TP2SS
TP2SS's Avatar
Drives: 2016 2SS Convertible
Just to clarify some comments made here, look at the date breakpoint in the TSB. If your car was made AFTER that date, the dealer DOES have to do the validation testing. If made between SOP (start of production) and that date breakpoint, your word is all that’s required.
Just had mine done with 4K miles. Told the dealer it was doing it intermittently (it wasn’t). They said they had to test drive to verify. I pointed out the wording of the TSB. They did the TSB. It’s about $450 if you have to pay for the fluid swap yourself (dealer, not diy). You may have waited too long, damage may be done. Hopefully they’ll do the TSB despite the mods, and replace the TC too, if required.
Hyper Blue/Ash Gray
A8
Magnetic Ride Control
Dual Mode Exhaust
2019+ version Split Spoke Silver Wheels
Navigation
Silver Rally Stripes
TP2SS is offline   Reply With Quote
Old 10-27-2020, 03:41 PM   #12
MANNAXMAN
MANNAXMAN's Avatar
+1
Despite what the TSB says about no diagnosis being required, YMMV depending on the dealership. I took mine to the two dealerships closest to me, and neither would perform the flush without first diagnosing it. I called GM Customer Service, and they sided with the dealerships.
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
Old 10-28-2020, 10:39 AM   #13
ctrlz
Here is a link to the verification procedure performed by the dealer:
https://gm-techlink.com/?p=11127
Old 10-28-2020, 10:49 AM   #14
Not much of a surprise, unfortunately. Dealerships that are actually in the business of customer retention are the only saving grace for GM on this issue.
