Old 10-23-2020, 05:45 AM   #1
Koulmc
Koulmc's Avatar
Drives: Chevy camaro ss
Camaro 2ss rear noises
Hey guys, I have a 2019 camaro 2 ss just hit 11k miles. What star started of as a grinding noise from the rear has gotten worse immensely, I read a few forums I seen people saying it was diff fluid. I went and did a differential fluid change and the problem is still here. I then took the car to the dealership, they had the car for almost 2 weeks and claimed they never hear the noise when they test drives it. Took the car back and has soon as I'm driving back home, the noises started again but worse than before. I will try to upload vids so you guys can help me pin point the problem
Koulmc is offline   Reply With Quote
Old 10-23-2020, 08:42 AM   #2
Invertalon
Drives: 2021 2SS
What fluid did you use for your differential change?
It was the one with the friction modifier, correct? AC Delco 10-4034 / #88862624
Invertalon is offline   Reply With Quote
Old 10-23-2020, 03:50 PM   #3
Koulmc
Koulmc's Avatar
Yes I used the ac Delco, went to the dealer and bought it through my vin #
Old 10-23-2020, 10:27 PM   #4
ctrlz
Well the diff noise is typically exacerbated by turning, as the clutches skip rather than slide smoothly.
If you hear grinding while driving straight it could be brakes or (less likely) bearings. You've got two possibilities for brake noise: the pads dragging on the discs or components of the internal drum parking brake dragging.
Old 10-23-2020, 10:36 PM   #5
PeteSS2018
Drives: 2018 2SS Camaro
I had the commonly heard 'groaning' noise especially when cold. It very rarely made the noise at all once the car was warmed up after a only a few miles. The dealer did the double diff oil flush out as recommended, the noise went away and has not come back in over a year. But it was never a grinding noise, more like a smooth deep groaning noise. I'd be taking it back if the oil flush hasnt fixed it, and are you sure its diff/rear axle??
2018 2SS, Hyper Blue, Australian HSV delivered
2.9L Whipple 98RON tuned 650hp/850Nm
Elite Engineering E2 Catch Can
Eibach Prokit springs
Mamo LT1 Ported TB
PeteSS2018 is offline   Reply With Quote
Old 10-24-2020, 10:05 AM   #6
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Grind or groan?
Old 10-28-2020, 03:50 PM   #7
Koulmc
Koulmc's Avatar
Thanks for all the help and tips guys... but I've finally found the culprit, it's my actuator that went bad.
Old 10-28-2020, 04:07 PM   #8
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Which actuator?
Old 10-28-2020, 07:05 PM   #9
njweatherman
Drives: 2018 Camaro 2SS, redline edition
Bump AvalonandI:
NPP actuators or the AFM actuators
njweatherman is offline   Reply With Quote
6th gen, camaro 2ss
