10-22-2020, 05:27 PM | #1 |
Drives: 2012 Camaro 2LT/RS Join Date: Feb 2019
Tire Sizing Help!!
Hi guys!! Excuse my ignorance I am horrible with sizing.. but I recently purchased a set of HRE FF04 wheels for my 2012 Camaro 2LT/RS. The sizes are 20x10 for the front two and 20x11 for the back two. What's the largest tire size I can get away with to fit my car? Site says 285/30R20 and 305/30R20 but I thought that would be too big? Customer Service isn't as helpful as I'd like either. Thank you!
10-22-2020, 08:51 PM | #2 |
Silver Shark
Drives: 2014 2SS GM Npp 6 speed manual Join Date: Nov 2014
You'll be fine! I have the same wheel and tire set up. No rubbing issues at all, plus it makes the car look more bad ass with those big tires sticking out back..
Silver Shark20*10,20*11 Z28 black gloss replica wheels, 285/305 tires, BMR Strut brace,Kooks lt headers/hfc, CAI cold air intake/air scoop
10-22-2020, 11:51 PM | #3 |
Drives: 2014 Chevy Camaro SS Join Date: Dec 2014
Mine has F 275/40r20 on a 20x10 and R 315/35r20 on 20x11. No issues whatsoever. I'm running the MRR M017 (6gen 1LE rims).
You should be able to run ZL1 size tires without issue which is F 285/35r20, R 305/35r20 and their oem offsets. |
10-23-2020, 07:43 AM | #4 |
Drives: 2014 camaro SS Join Date: Jan 2019
those are the sizes I went with, stock size for ZL1. I also chose "all weather" tires, much better than the summer pirelli "skates" where I live. unfortunately this is the ONLY manufacturer who makes all weather in those sizes. no clearance issues at all.
10-31-2020, 12:29 PM | #5 |
Drives: 2010 ss Join Date: Nov 2019
Yes I also run 315/35r20 on my rears nonissue
10-31-2020, 12:44 PM | #6 |
I have heard of some people having to tie their parking brake cable back when running 315's, but it doesn't look like it happens to everyone. I wonder if it's a model year thing.
11-01-2020, 10:09 AM | #7 |
I am running 275/35/20 front's 20x10 and 315/35/20 rear's 20x11. I did have 335/30/20's on the rear for a while with no clearance issues at all, and I'm lowered 1.25 all 4 corners.
