Old 10-22-2020, 09:47 AM   #1
clg82
Drives: 2020 Camaro ZL1
Can’t wax heat extractor?
I was reading the supplemental owners manual last night and it said you can’t wax the heat extractor. Any reason behind this? It’s a painted surface. Is anyone else here waxing it? I’m about to do a full detail on my ZL1 and found that statement kind of odd.....thanks for any help!
Old 10-22-2020, 09:53 AM   #2
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
The carbon one maybe, Mosiac Black? Go for it, mines been waxed since day one.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 10-22-2020, 09:55 AM   #3
clg82
Thanks for the response Jon, so here is a very dumb question, I am unsure if my car came with the carbon one, how can I tell? Is there a code on the door jam that tells me if I have it?
Old 10-22-2020, 10:29 AM   #4
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
The Carbon one is exposed Carbon Fiber. Does your HE look like carbon fiber or is it just black?
If it is CF, there are coatings that work well at protecting the CF and preventing the sun from causing discoloration.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 10-22-2020, 12:30 PM   #5
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
Mine spends the majority of its time in a garage but I just put a ceramic coating on my carbon one while I was doing the entire car.
Jaxcam02 is offline   Reply With Quote
Old 10-22-2020, 01:43 PM   #6
Markoz28
Drives: 18 ZL1 nightfall grey A10
Power Lock sealant put all over the car including carbon HE and windows. No problems what do ever. This is every 3 months
Markoz28 is offline   Reply With Quote
Old 10-22-2020, 02:26 PM   #7
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
Ceramic coating on mine and no problems.
MartinLe is offline   Reply With Quote
Old 10-22-2020, 02:40 PM   #8
Krowser
Krowser's Avatar
Drives: ZL1 Mosaic Black
IMO you can wax the exposed carbon fiber heat extractor.
I wax mine every week with my car washes; HOWEVER, it must be done a certain way:
1. I only wash with Maguiar's Ultimate Soap and water. (don't press too hard)
2. Dry with waffle cloth. (again...don't press too hard)
3. Apply Collinte 9 series wax with clean/new applicator. Its a upper mid tier carnauba wax. Note: polymer waxes may have abrasives and may not be suitable for the exposed carbon coating. Carnauba is not as strong as polymer waxes, but with a high quality carnauba, you should be ok.
4. Remove wax with a HIGH QUALITY rag. (Rag Company: Eagle Edgeless)
5. Repeat every week!!
Krowser is offline   Reply With Quote
Old 10-22-2020, 05:08 PM   #9
Bowman_ZL1
Bowman_ZL1's Avatar
I put 2 coats of the Griots 3 in 1 on mine. No issues at all...
Bowman_ZL1 is offline   Reply With Quote
Old 10-22-2020, 05:39 PM   #10
clg82
After looking closer I do not have CF so it is just painted, I tried a very small conspicuous area first to test and it was fine....thanks everyone for the help! This forum is a great place to find information. I’ve spent more time here than driving my new ZL1 haha
Old 10-22-2020, 07:06 PM   #11
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
as long as it has a clear coat on it should be just fine
Old 10-22-2020, 08:50 PM   #12
HypeBlueZL1
Drives: Chevrolet Camaro ZL1
The exposed carbon fiber has clear coat on it (that's what you pay for). I've used collinite on mine and it is fine. In fact I would recommend it. The mosaic black painted carbon fiber can of course be waxed like any other painted surface as well.
HypeBlueZL1 is offline   Reply With Quote
Old 10-22-2020, 09:10 PM   #13
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
The info on heat extractors is referring to the plastic pieces in the hood of an SS Camaro. The ZL1 has a different hood obviously. Treat it the same as the rest of the car's painted surfaces.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 10-22-2020, 09:14 PM   #14
ZO6 Bryan
ZO6 Bryan's Avatar
This
Bryan 2018 ZL1 M6
