Old 10-21-2020, 04:47 PM   #1
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
Auto seat recall works --- Sometimes???
Sometimes my seat recall works when I start my car and sometimes it doesn't and I have to manually push the seat recall button on the side of the door.
Has anybody had this problem and if so, how did you fix it?
MartinLe is offline   Reply With Quote
Old 10-21-2020, 07:11 PM   #2
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
Yes and no I just turned it off
Jaxcam02 is offline   Reply With Quote
Old 10-21-2020, 07:38 PM   #3
19Nasty1le
Craig
19Nasty1le's Avatar
Drives: 2019 ZL1 1LE
Yeah same here or I can tell it’s moved forward a bit and not all the way when I hold “1” it’ll move a bit closer, annoying. Also if you take off the e brake or anything too quick it’ll quit adjusting
19Nasty1le is offline   Reply With Quote
Old 10-21-2020, 09:56 PM   #4
JasonGofast
Used to own a ZL1
Drives: '16 Z06
Manual issue? I never had it happen. Maybe wrong key fob? The auto recall is matched to the fobs aren't they? I would just try setting it again.
JasonGofast is offline   Reply With Quote
Old 10-22-2020, 05:41 AM   #5
CasualGuy
Drives: '19 ZL1 1LE | ‘19 MX-5 Miata 30AE
The parking brake must be set for auto seat recall to operate. If you’ve just left the car in gear without setting the e-brake, the seat won’t move on its own.
CasualGuy is offline   Reply With Quote
Old 10-22-2020, 07:32 AM   #6
Jaxcam02
Jaxcam02's Avatar
I just had to replace a battery in one of my key fobs. I may reactivate it and see if it works correctly again.
Old 10-22-2020, 08:28 AM   #7
Kmeleon
Drives: 2018 NFG 2SS 1LE!
Winner winner chicken dinner
Kmeleon is offline   Reply With Quote
Old 10-22-2020, 01:09 PM   #8
MartinLe
MartinLe's Avatar
That sounds like a winner to me. Thank you very much for the suggestion.
