Old 10-20-2020, 02:35 PM   #1
Carress
Carress's Avatar
Drives: 2017 Chevrolet Camaro LT
Question 2017 Gen6 TIMING Gasket Cover Leak
Has anyone had this issue w/ their 2017 RS 2.0 turbocharge ?? Bought it in 2019 had 17,000 miles on it. Had a routine oil change and the dealership said it was starting to leak.. around 50,000 mm
THANKS
Carress is offline   Reply With Quote
Old 10-20-2020, 02:49 PM   #2
gtfoxy
Drives: '21 Wild Cherry ZL1
WTH is a gasket cover?
Is that where you put the blinker fluid in or something?
Old 10-20-2020, 03:00 PM   #3
Carress
Carress's Avatar
TIMING gasket cover...
Old 10-20-2020, 04:31 PM   #4
gtfoxy
Don’t see a separate gasket listed, just the cover itself. $90 + $15 for front crank seal from gmpd. Probably like an LS cam plate, can only buy the cover w/ gasket.
Check to make sure the bolts are still tight, otherwise get a damper puller & DIY it.
May need to loosen the front oil pan bolts & drop it out of the way.
Old 10-22-2020, 12:13 PM   #5
Carress
Carress's Avatar
Thank you! I will look into that for sure.
Old 10-24-2020, 04:21 PM   #6
1LEThumper
1LEThumper's Avatar
Drives: 2020 2SS 1LE
Unlike the LS the LT doesn’t use many gaskets. The front cover is glued on with RTV. The oil pan and rear block cover are the same way save for a couple o-rings.
1LEThumper is offline   Reply With Quote
