![]() Drives: 2018 Camaro SS convertible Join Date: Jul 2018
Npp actuators
Has anybody figured out a way to wire up the npp actuators for power on a non-npp SS???
Patriot
Drives: 2019 Camaro 1SS 1LE Join Date: Sep 2020
some custom wiring of this guy should work for ya
https://www.corvettegarage.com/c7-co...haust%20system.
2019 Camaro SS 1LE M6, Ported LT2 Manifold w/ 95mm TB, Flex fuel, Kooks Longtubes catless to NPP, Big Gulp intake, TSP EL-C7 cam w/ Titanium valves and dual Springs, 605HP at the tire N/A
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Convertible Join Date: May 2012
The Mild2Wild and similar controllers allow you to remotely remove or apply power to the NPP exhaust system. They don’t have the ability to control the NPP actuators directly. The NPP actuators are still controlled by the car’s BCM computer. I haven’t seen anybody post that they have added NPP to a non-NPP Camaro.
Patriot
ah i thought the mild to wild worked as a stand alone cutout. in that case
holley makes a stand alone cutout with a wireless remote... seems that would be cheaper and easier than factory npp thats just me
![]() ![]() ![]() Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
You would have to use HP Tuners to full flash the chassis control module to an operating system that supports the NPP. That is I am assuming the non NPP models have the same CCM and are just different software to control the NPP. I am almost positive a factory tool won't do it either and im not sure if HP can even full flash the CCM.
