Old 10-18-2020, 08:22 PM   #1
parish8
Drives: 17 SS a8
New best 60’, I want more
I cut a new best 60’ last night. 1.43. The new best just makes me want more.
My set up was 325/50/15 et street r at 17psi. Viking rear shocks at 4 comp, 10 rebound, I think there are 19 clicks. Healthy burn out with lots or rocks on the tires when I get back to the pits. 4000rpm 2 step and letting it go when it gets to 7psi. This is on a foot brake, stock gen v turbo 5.3.
When I tried to leave at 9psi it spun a little right off the line and slowed down. It didn’t blow them off, more of a shudder, still got a 1.45. I could leave with quite a bit more power if I can get it to hook. Probably 4200rpm and 13psi.
Where do look first for improvements? Tire pressure? Shock settings? Skinnys sauce?
I found one site where they suggest 11-14 psi for this size of this tire. Do people go that low?
Old 10-19-2020, 10:12 AM   #2
BDPhoto519
BDPhoto519's Avatar
Unfortunately I don't have much in the way of advice... That's a pretty solid 60 foot!
90% of my racing with this car so far has been in Mexico so the setup is a little bit different. I have had good luck with some ballast & tire sauce on an ETR.
I do have a question though. How was the fitment of the 15" 325 ET R's. Do you think they would fit ok on stock suspension still? I am in the process of switching over to 15's and I would really like to run that tire instead of my current 305/45/17.
Thanks,
2018 Camaro 2SS A8 Redline Edition
BDPhoto519 is offline   Reply With Quote
Old 10-19-2020, 10:42 AM   #3
parish8
Drives: 17 SS a8
Thanks,
I will eventually play with some traction compound but feel there is more in it before I go there. I do have some weight in the trunk, intercooler tank and chiller are both back there and seemed to have made hooking quite a bit easier.
All you need is the basic 15” wheel kit and the 325’s will fit. I did the harness relocation awhile back too.
Old 10-19-2020, 11:03 AM   #4
BDPhoto519
BDPhoto519's Avatar
Thanks, appreciate the info... Do you have a preference on the 15" kits?
I see there is the usual big players, and a few options for a DIY with the 14+ CTS calipers.
Old 10-19-2020, 11:09 AM   #5
parish8
Drives: 17 SS a8
I have the Carlyle brake set up. The 1st gen calipers started leaking so I got their 2nd gen ones. They seem better but not great. I never have got my pedal feel back but they do a fine job stopping the car. I only feel the soft pedal when I am mashing the brakes on the starting line.
The ctsv set up might be better than what I have.
Old 10-19-2020, 06:08 PM   #6
gtfoxy
Drives: '21 Wild Cherry ZL1
Does it feel like it’s squatting to the right more than the left at all?
Congrats!
Old 10-20-2020, 04:37 PM   #7
jorgesvlog
Drives: 2019 Chevrolet SS
Nice 60'! I was able to pull off a 1.42 which was my best, and not sure if ill be able to do much better unless i spray a little more than the 40% i have it set at right now. Im on a 17 in et street r with nitrous basically off the hit on a stock converter. I would love to get a 1.3X 60' but not sure if that will be possible on the complete stock suspension.
jorgesvlog is offline   Reply With Quote
Old 10-20-2020, 05:03 PM   #8
laynlo15
Drives: 2022 Lt1 A10
My best 60ft on stock suspension setup was 1.40 60ft and once I did the Bmr was 1.38 when I was still on my 2300 Maggie. When I went to the 2650 my best was 1.35 and we fought traction issues sometimes with 100 more rwhp. I was on a 17" Street R and probably would have benefited with the Carlyle 15" and a 325 Street R like some have started running with a bunch of HP. Now the Turbo car will benefit most with the correct converter where mine was on the stock tranny and converter.
Old 10-25-2020, 11:32 AM   #9
JimW
JimW's Avatar
Drives: 2011 Camaro
I’ve been playing with a new tire .. Hoosier bracket drag radial .. 305/45/17 on beadlock .. best so far is 1.38 at 21 psi air pressure .. stock suspension .. haven had them below 20 psi yet .. yesterday at 23psi cutting 1.4s .. only got two runs.. was down on power and I’m done for the year. 😞
2017 Garnet red ZL1 A10 Procharged LME 427 L8T
JimW is offline   Reply With Quote
Old 10-27-2020, 04:17 PM   #10
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
I have a question about this tire you have, is that the 28.0/10.5 R17? thats a great 60 foot and a bunch of air!! My best on the 305/45 17 M/T ET street R's is a high 1.42 but with 17 Lbs of air in them! and they are MUCH cheaper than the M/T's!
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 11-02-2020, 02:02 PM   #11
laynlo15
Well I just saw you busted that in another post with a 1.35. Congrats again
Old 11-11-2020, 07:48 PM   #12
JimW
JimW's Avatar
Drives: 2011 Camaro
Yes that’s them .. like said I only got 6 runs .. but they seem pretty consistent.. I was running them on the street at 30psi .. they hooked well on the street also .. but they have zero tread..so rain would be bad .. very little sway like the mickeys.
