Old 10-18-2020, 09:44 AM   #1
LSA
Drives: Fast
DIY Home Alignment
If you are doing DIY home alignment, please post details about your setup/process.
Particularly, if you have confirmed your settings with a commercial hunter rack for verification.
I tried smart strings on a previous car and was not pleased.
LSA is offline   Reply With Quote
Old 10-21-2020, 03:22 PM   #2
Hops
Hops's Avatar
Drives: 2019 1ss 1le, blue wrap
I have a DIY for the front.... but haven't done the rear yet.
https://www.camaro6.com/forums/showthread.php?t=560773
Hops is offline   Reply With Quote
Old 10-21-2020, 11:26 PM   #3
MTSS1LE
Drives: 2007 C6 Z06
I've gotten my toe within spec using this string box technique, confirmed when I got the alignment checked at a shop later on. Does individual toe not only total toe. Takes a lot of trial and error though, I wouldn't recommend it unless you really need to do it DIY.
MTSS1LE is offline   Reply With Quote
Old 10-25-2020, 07:43 AM   #4
cdb95z28
cdb95z28's Avatar
I started a thread over on camaro5, but I haven't finished it, summer is too busy. Once the weather turns cold, I'll be adding to my thread:
https://www.camaro5.com/forums/showthread.php?t=566970
"KEEP THE FAITH"-Fbodfather
