Old 10-18-2020, 09:26 AM   #1
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
Removing M6 trans
I have to pull my TR6060 next weekend to get it rebuilt after something came apart internally and will also be putting in a McLeod or RAM clutch. Does anyone have any tips they can share for pulling/installing this manual trans and clutch? It will be done on a lift and I should have all the needed tools. Any special care needed for the throw out bearing or slave? Haven't dealt with a hydraulic clutch in a while. I appreciate the info!
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 10-18-2020, 11:05 AM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Here is one thread that talks about it. If you search you’ll find a few others.
https://www.camaro6.com/forums/showthread.php?t=566392
Old 10-18-2020, 02:55 PM   #3
nprario
nprario's Avatar
Drives: 2017 1ss 1le HBM
This video shows you everything.
https://www.bing.com/videos/search?v...OeuDe%252F534Q
nprario is offline   Reply With Quote
Old 10-19-2020, 12:16 AM   #4
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
Perfect!
Tim M is offline   Reply With Quote
Old 10-19-2020, 07:12 AM   #5
Jhunsberger
Originally Posted by nprario View Post
Thank you for all the feedback!
Old 11-08-2020, 05:57 AM   #6
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
the 2017 manual says lower rear of engine cradle 5" the 16 manual says 1" like in this video. I had to lower mine 5 to get it out.
Old 11-08-2020, 09:56 AM   #7
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
Make sure you lower the cradle, if not you’ll be fighting the trans against the firewall to come out.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 11-09-2020, 10:59 AM   #8
Jhunsberger
Will do, thank you for the feedback. I am pulling it this weekend finally.
Old 11-16-2020, 12:39 PM   #9
Jhunsberger
Once the car was on the lift it took about 3 hours to get the trans out, there were 2 of us working on it. It wasnt too bad really. The Whipple i think got in the way of the engine tilting back to get the trans out. You could see the SC was against the firewall/cowl. So we ended up having to pull all 6 engine cradle bolts out and pitching the cradle around top get the trans out. We had to roll the trans in the tunnel some to get it to come out. The shifter assembly was a little tricky to get out before pulling the trans as well. The clutch and pressure plates looked in surprisingly good shape considering the abuse it has seen. Should have the rebuilt trans back in about 4-5 weeks and a Mcleod RXT clutch and Hurst short shifter to go with it.
Old 11-17-2020, 08:55 AM   #10
MeanGreen1LE
MeanGreen1LE's Avatar
Drives: 17 krypton green 1le
Are you replacing cradle bolts? I’ve seen somewhere they are TTY.
MeanGreen1LE is offline   Reply With Quote
Old 11-17-2020, 10:09 AM   #11
Jhunsberger
No, didn't plan on it. I really doubt they are torque to yield, considering it didn't take much at all to loosen them. But I will look into it.
Old 11-23-2020, 10:47 AM   #12
L78toLT1
L78toLT1's Avatar
Hey Jhunsberger, what are the details of your tranny rebuild? Seems to me that swapping in the gear sets from an LT4 would be a good upgrade. 500 to 650 torque rating increase combined with slightly better gear ratios.
Baby Blue
Old 11-23-2020, 12:04 PM   #13
Jhunsberger
I don't have all the specifics yet, waiting till they get it tore down and see what failed. But I will looking into the LT4 gear set suggestion, that might be a good move, Thanks!
Old 11-23-2020, 01:52 PM   #14
L78toLT1
L78toLT1's Avatar
Who’s building the trans for you? I’ve heard good things about Tick, but I expect there are other competent builders out there. It will be interesting to see what failed, whatever it is, hopefully your case is ok. If not, your best bet may be to find a salvage unit out of a ZL1.
How many ¼ mile passes do you reckon you have on your trans? If I recall, you’re not exactly a stranger to the strip. I’m sort of surprised your trans turned loose before your diff, or your clutch for that matter. My diff is on its last legs and I haven’t done much drag racing at all, just a bunch of sessions on various road courses. Several of the faster auto trans guys have had diff failures. I’m certainly not wishing you bad luck, but apparently you got a good differential. I’m going to perform an autopsy on mine after my last track day of the year at Road Atlanta on December 5. My diff is getting so sloppy, I’m a little nervous about it. One of my buddies trailers his 1LE, so as long as we don’t both break something, at least I won’t have to pay a big tow bill.
Baby Blue
