Old 10-16-2020, 11:59 PM   #1
stlwrx
Drives: 2020 LT1, 04 JDM STI, 18 BMW
2020 LT1 at the track tonight
Took my 2020 LT1 to the track tonight - bone stock A10, with AWE axel back.
Only got two runs in best being a 12.202 @118. with a crappy 1.95 60 Foot.
Was pretty chilly tonight, around 45 degrees so I'm sure that was an issue. Was running a rear drag pack and she definitely had a high 11 in her if I was better at launching and such.
stlwrx is offline   Reply With Quote
Old 10-17-2020, 07:54 AM   #2
laynlo15
Drives: 2022 Lt1 A10
Congrats on a nice pass.
Old 10-17-2020, 06:34 PM   #3
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Good pass. I consider 1.95 good for a 60’!
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 10-20-2020, 07:15 AM   #4
wnta1ss
What kind of tire on the rear drag pack?
Old 10-20-2020, 08:55 AM   #5
laynlo15
I don't see a 1.95 as a good 60' with a drag pack on the rear. Most stock Camaro's with street tires on the right track can cut 1.70s and 80s. Maybe just not launching correctly but the MPH was really good. Were you trying to launch brake torqueing it or were you leaving right off idle. I think most have found that right off idle works best with stock converter and basically no mods.
Old 10-20-2020, 12:17 PM   #6
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
I would consider 1.9 on a stock m6 car good.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 10-20-2020, 02:02 PM   #7
laynlo15
Not on a A10.
Old 10-20-2020, 05:07 PM   #8
wnta1ss
OP clearly identified his car as an A10 in the original post. He also said it had an AWE axleback and a rear drag pack.
I do agree with the OP and laynlo15 that 1.95 is not the kind of short time that I would have expected for that package either. My own experience was that on my first run with drag radials on the back of my A8 SS, I got a 1.76 short time.
Old 10-20-2020, 08:49 PM   #9
laynlo15
for sure SS
Old 10-20-2020, 09:52 PM   #10
stlwrx
It was my first time at the track ever in this car and I was messing around with launching from different RPMs. the 12.2 was from 1100 RPM - I never got around to trying off idle - only got two runs in as the track was packed. The temp for both passes was around 44 degrees. Also, the tires on the rear were Nitto 555Rs so maybe not pure drag pack per say.
Old 10-20-2020, 11:04 PM   #11
laynlo15
I run the 555r2s on my C7 and they hook great. Just try the right off idle, no launch control. Right off idle lets the converter flash and should see quicker 60ft times. I've tried 1000, 1200 to 1500 and all have proven to be slower then flat footing if right from idle. Do your burn out past the water a foot or two. If you do the burnout in the water then when you roll to the line the water drips down on top of the tires. So roll thru, take all the nannies off and do your burnout, these R2s don't need to be smoked to death, just get them smoking and keep your foot in it and let off the throttle some as you take your foot off the brake. Roll right to the line and get ready for launch. If no ones there to help you stage just put your drivers mirror all the way down so you can tell when you have rolled thru the water and on dry pavement. In 52 years of drag racing I've been down the track a couple thousand times or more and I've done it all and sometimes not right so just trying to help you out.
Old 10-21-2020, 06:24 AM   #12
wnta1ss
Just takes some experimenting is all. Try launching from an idle next time and see what it does.
As far as your 555R tires, they should be fine for an auto car. Have seen someone post running in the 10s using those tires on the back of an auto car with over 600whp, so I don't expect them to be an issue for your auto car with ~400.
Old 10-21-2020, 11:02 AM   #13
RobbyBeefcake87
That was meant in reply to vtirocz's comment, who considers a 1.9 60' good as he's an m6 guy as well. Hope this helps.
Old 10-22-2020, 09:58 AM   #14
s346k
s346k's Avatar
Drives: like an old lady
depending on tire size the drag radials may be hurting more than helping
