![]() Drives: 2018 2SS Camaro Join Date: Mar 2020
Elite Engineering Catch Can
A minor mod I know; but just to share my install.
Gotta say, my experience with Elite Engineering has been nothing short of excellent. Here in Australia there are very few camaros, so not a lot of gear specifically for them or expertise on the LT's, and I don't have much real prior knowledge of DI motors. After having a Whipple SC installed about 6,000miles ago, I asked Whipple by email if they recommended a catch can for my installation. Their response was that its not absolutely required, but definitely a good addition. I then did some 'google research' and asked some questions here .... and realised that a dual outlet ported can would be better with boost. Other than McNally and Elite I couldn't find another suitable option. I emailed both and in fairness both came back to me within maybe 24 - 48 hours. But I went with Elite because they had quicker/cheaper shipping, better pricing for my use and I have to say, exceptional responsiveness to my email questions. Plus I could get all I needed eg check valves etc in one order. But I'd have also been happy to buy the McNally unit. Elite were very responsive (before and after I ordered), the kit arrived perhaps 2 weeks after I ordered it, very nice & well built product. The only thing I'd say is, there should be some basic instructions for those who don't know how to route these/where to connect (I had no issues but some might get confused esp. With a SC use). A single sheet of paper, 6 or 8 dot points and half a dozen photos are all that's needed. I'll do one for you if you like Elite
2018 2SS, Hyper Blue, Australian HSV delivered
2.9L Whipple 98RON tuned 650hp/850Nm Elite Engineering E2 Catch Can Eibach Prokit springs Mamo LT1 Ported TB |
Moderator
Good stuff! After a few thousand miles you should pull the top off the blower and see if there is any oil on it. Same thing with the intake elbow.
Had to take of the intake as part of that install. Totally clean & dry; however there was a little build up on the throttle flap which I cleaned off.
![]() Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
Next mod is to get yourself a larger intercooler filler tank on there, I doubt you're getting all the air out of your intercoolers with that setup. You want the reservoir (and water level) above the intercoolers if at all possible - maybe switch to something like this:
https://superchargersonline.com/prod...ler-reservoir/
#5 | |
#6 | |
Moderator
The Whipple comes with a 2 gallon intercooler reservoir that mounts to the crash bar behind the front bumper cover. The little “reservoir” you see is only the filler neck and pressure cap. It’s actually not too bad in terms of getting the air out of it.
#7 | |
#8 | |
Moderator
#9 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
Is there an adapter for using a hand vac?
#10 |
![]() Drives: Camaro Join Date: Mar 2016
What did you pay for the elite? I've been trying to get pricing from them for a week and can't get it.
#11 |
There is, kit we had was from snap-on or matco.
#12 |
Its all on their website, depending on what can, fittings, hoses etc. I had delivery to Australia also, so I think about $300 USD or so plus postage
#13 |
#14 |
It's designed for all cooling systems, it's a cap that screws on the top of the reservoir, then uses compressed air evacuate the system, and the vacuum then fills the system. It works good, but I've found it easier to just mount a high reservoir that can purge and fill as the pump is running.
