Magnuson 2300 canned or custom tune with lt1 fuel system
Hey all,
I have a bone stock 17' ss 1le. I daily drive the car at this point. I've wanted to supercharge the car since buying it. I'm ready to pull the trigger on a magnuson 2300. I've done alot of research on this forum before setting what I consider realistic power goals from this upgrade. Id like to hang right around 550whp. I know the lt1's fuel system would limit the boost to right out the box. I fully intend to build the car further just not while i'm utilizing it as a daily driver. My question is knowing my power goal around 550whp does it make more sense to just buy hp tuners or other tuner and load the canned magnuson tune or spring for a remote tuning package? |
#2 | |
The 2300 is a great choice, giving you a fair power level for the street that is safe for the LT1 without upgrading internals.
If you have Ted tune your car or another tuner you'll need HP Tuners. You'll have to be able to load a tune from whom ever it is and also need to do some logging to make sure its all good. Buy the MPVi2, don't get the canned tune if you plan other mods in the spring. they are always a little rich. Ted's probably done more Maggie remote tunes on the forum then any tuner. I would also get a Roto Fab when you purchase the 2300. You'll make some more power and since you getting a customer tune you'll be well on your way. Let me know if you need anymore info.
![]() Drives: 2019 SS Join Date: Apr 2020
Call Ted Jannetty I believe he can remote tune those or at least get you a good tune.
#5 | |
What size pulley did you end up with to run 7.5psi? 95mm? Did you do all of your upgrades at the same time? |
![]() Drives: 1SS Summit White 6 speed Join Date: Jul 2017
I have Rotofab with my 2300
Vengeance racing tuned my car 550/541 car drives great but I'm at the limit of the LT1 fuel system 1LE's have some LT4 fuel parts so your ceiling should be higher than mine Before you order speak with the guys at Magnuson and see if you can get a slightly smaller pulley and tune
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
#7 | |
![]() Drives: 2012 GMC Sierra, 2018 Camaro SS 1LE Join Date: May 2016
Fuel System Parts / Vengeance
#8 | |
I got the supercharger plus the intake and the voltage booster first, then the LT5 throttle body in a second step with a retune. The dyno numbers I quoted were produced with the LT5 throttle body.
#9 |
They won't offer that because if a smaller pulley is added with a Magnuson tune it won't pass Carb and they won't risk loosing carb cert for a sale with a smaller pulley and a Canned tune. It won't happen. How do I know? Well lets just say I worked there and we had customers ask that all the time. Get a custom tune or get a canned tune with no mods, just the blower
#10 |
I appreciate all you guy responses, just looking at cost vs reward... giving me more to think about, had been thinking about a rotofab already, if I get a custom tune I would likely go with a 95mm pulley... like you guys mentioned id want to consult ted/magnuson before going a
My original thought was save some $$$ going with just the supercharger and canned tune instead of spending the extra money for the custom tune. Seems like running 7.5psi boost pressure will be the incentive for a custom tune. Side note: I was kickin around the idea of letting vengeance tune my car too, I really couldn't find alot of information about them tuning direct injection engines... im interested in your experience to asthmamax11. @laynlo15 I think I read where you had a 2300 and you guys made several changes and tunes? Any opinion on pulley differences between a 98mm and 95mm in this case? |
#11 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
As far as doing that 2300 with the canned Magnuson tune, my opinion is, don't do it. I have seen an SS with the Magnuson canned tune and the 2300 blower and it was pretty weak. Dragstrip performance was weak and dyno test was only in the 480s. Not even close to your 550whp expectation in other words. Seems to me that you would need to get a custom tune done or you could be in for some disappointment.
#12 | |
![]() Drives: 2018 chevy camaro ss Join Date: Feb 2021
+1 for this. I got the Maggie 2300 with the canned tune. I'm at 508hp 506tq. I'm not that happy. Going back for a rotofab, smaller pulley, and a tune.
2018 Camaro SS. Maggie TVS 2300.
#13 |
My tune is from Ted Jannetty and the car made ~560 rwhp / ~540 rwtq with safe timings, so clearly there is a lot left on your table.
