Old 10-07-2020, 07:09 AM   #1
CHASLT1
Drives: 2021 Camaro LT1
V4 V8 mode?
How does the AFM work with the 2019 and up A10 auto's? It was clunky and sucked with my 2019 C7 A8 auto. Range does not have a device yet for the A10 so i would have to live it for a while.
CHASLT1 is offline   Reply With Quote
Old 10-07-2020, 08:38 AM   #2
Invertalon
Drives: 2021 2SS
I never really notice the switch between V8 and 4-cylinder mode. Unless I look down at the display to see what mode it's in, I can't tell.
Invertalon is offline   Reply With Quote
Old 10-07-2020, 10:23 AM   #3
Never noticed the switch either while AFM was enabled on my car, the transition was super smooth (and I have the A8).
The only giveaway, if I wasn't staring at the V8 or V4 symbol in the cluster, was the temporary lack of power.
Old 10-07-2020, 12:20 PM   #4
BrandanK
Drives: 2021 Camaro SS 1LE
I have a 2020 LT1 with the A10. The transition is completely seamless. Honestly, GM nailed the tuning between the A10 and the AFM. The car cruises very well at highway speed, and then grabs the require gear as soon as you start to roll into the gas.
I also have a 2016 GMC Yukon with the 5.3 L83 and the 6L80, and I cannot say that it is as smooth. Don't get me wrong, they did a great job here also, but I can hear the tone change in the truck when it switches to V4 mode. The A6 obviously isn't as responsive as the new A10 either.
Both great vehicles.
Brandan
BrandanK is offline   Reply With Quote
Old 10-07-2020, 12:43 PM   #5
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
You can't even notice it changing, the A10 is great. Range DOES have a device to disable AFM (I have one on my 2020 2SS)... https://www.rangetechnology.com/prod...r/parts/RA003R
(The AFM/DFM Disabler is NOT currently compatible with 2019+ 6.2L 10-speed Silverado and Sierra models.)
Old 10-07-2020, 12:49 PM   #6
Ron2ss
Ron2ss's Avatar
Drives: 2020 2ss vert
Last October I sent an email to Range asking them if the device would work with my 2020 A10. The answer was that it would work fine. I purchased it and have been using it for a year now with no issues whatsoever.
Ron2ss is offline   Reply With Quote
Old 10-07-2020, 01:13 PM   #7
Gr3m27
Drives: Camaro
When I had it enabled it was fine. The car did spend a lot of time in V4 mode while in the city which was fine but it did seem to have a slight lag when punching it. TBH it was one of the first things I turned off when we started tuning the car and I haven't missed it. Also, I didn't see any change in fill ups without it.
2017 Chevy Camaro Hyper Blue 2SS A8
2017 Chevy Camaro Krypton Green ZL1
Gr3m27 is offline   Reply With Quote
Old 10-07-2020, 01:28 PM   #8
Invertalon
Drives: 2021 2SS
Does it work on the 21's? I thought there was a change on the 20/21's that might cause issues with things such as this. Perhaps I am mistaken, though.
Old 10-07-2020, 01:49 PM   #9
2SS Capt
2SS Capt's Avatar
It should work fine on a 2021, in 2020 they changed the Transmission controller but the Range device still works, the 2021 has the same controller as the 2020...
Old 10-07-2020, 02:06 PM   #10
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
I had a C7 M7 and I tried the AFM when I was driving from Edmonton to Fort McMurray by putting the car in ECO mode. Other than the subtle exhaust tone and some minor vibration in the shifter(which you are not supposed to rest your hand on in a manual car anyway), it worked pretty well.
Can't imagine it being that different in the Camaro, but mine is a 6-speed so I don't even have that functionality. To each of their own.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 10-07-2020, 02:30 PM   #11
az4783054
Drives: SWXXZL1
One month ago I inquired with RANGE TECHNOLOGY if they have a module yet for my 2020 ZL1 with A10. The tech said they currently did not have a specific module for the car and if I were to use the #RA003G from my previous C7 Z06 with A8, it may not not work properly ("erratic shifting").
I sold my module and will wait for the development of an A10 specific module.
FWIW, the inquiry was answered by HOLLY tech support. HOLLEY evidently purchased RANGE recently.
"Joe" does a hilarious impression of a slinky toy on stairs.
az4783054 is offline   Reply With Quote
Old 10-07-2020, 02:58 PM   #12
2SS Capt
2SS Capt's Avatar
Right from Range's website...
I've been using it on my 2020 2SS A10 for several months, working fine...
Old 10-07-2020, 03:11 PM   #13
RyanR623
Drives: SS A8, NPP, Red Hot
In mine i can feel it, if i pay attention, it's like a tiny loss of power, like it slows the car .001mph, and gets quieter. So definitely not jerky. Why would the transmission matter? Does the transmission do something when we switch to V4? I thought it just deactivates the cylinders and closes the valves?
RyanR623 is offline   Reply With Quote
Old 10-07-2020, 04:50 PM   #14
It doesn't, but somehow every other thread around AFM turns into an A8 bash fest, even though AFM only promotes the symptoms of shudder and does not cause it.
