Old 10-05-2020, 08:22 PM   #1
kdm123
Drives: 2018 ZL1-1LE
Can't disable stability control
For some reason my car won't allow me to disable the stability control. I am pressing down on the TC button, I see the TC light go on, but the stability-control-off icon does not come on. I've had no trouble with this before. The car is in Tr mode with cruise control off and car at stand still.
kdm123 is offline   Reply With Quote
Old 10-05-2020, 09:57 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
be patient...hold it down for 5-7 seconds...you get one light then the other
Old 10-06-2020, 04:11 PM   #3
kdm123
I've held it down for 30 seconds but it won't disable. I haven't had this problem before so I'm wondering if I'm doing something wrong or if there's an issue with the computer.
Old 10-06-2020, 04:53 PM   #4
grampa_ss
grampa_ss's Avatar
Pretty sure it's 2 pushes of the T/C button. Just realized this is a ZL1, sorry. The 2 pushes works for the SS.
Old 10-08-2020, 07:53 AM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
page 228:
https://my.chevrolet.com/content/dam...ers-manual.pdf
Old 10-09-2020, 06:33 AM   #6
iwk2much
Drives: ZLI 1LE; 992 S; GLE 450, Denali HD
If you have have one or more TPMS not registering or have low pressure, traction control will not completely deactivate.
iwk2much is offline   Reply With Quote
Old 10-09-2020, 09:00 AM   #7
Deadpool Z
Deadpool Z's Avatar
Drives: Chevrolet ZL1
Are you in Sport or Track mode when you do this? I know it won't disable in Touring and Ice/Winter mode. I was getting frustrated once and realized that was my issue.
Deadpool Z is offline   Reply With Quote
Old 10-09-2020, 08:33 PM   #8
Og Neon
Lover of Speed
Drives: 2018 ZLE
Not true. I have that scenario happening and I have never had an issue turning it all off.
Killer Whale Racing
2021 One Lap of America Track Videos
2019 One Lap of America Track Videos
2017 One Lap of America Track Videos
2022 Ram TRX
2018 Camaro ZL1 1LE
2020 Range Rover Sport SVR (Sold)
2014 Grand Cherokee SRT (Sold)
2014 Camaro Z/28 (Sold)
Og Neon is offline   Reply With Quote
Old 10-10-2020, 02:09 AM   #9
Yves ZL1
Yves ZL1's Avatar
Drives: Canadian 2019 BLACK ZL1
I think this is a canadian version... mine can’t be disconnected also....
Yves ZL1 is offline   Reply With Quote
Old 10-12-2020, 09:20 PM   #10
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
Second this. If the TPMS reads 15 psi or less, mine won't turn off SC either, or at least the disabled light won't come on.
If you put the car in Sport Mode, you can also double tap TC button to enter Competitive Mode, which all but turns off SC. For the longest time, I didn't think there was any SC in Comp Mode, but I finally got it to reduce power a tad one day with a massive drifting burnout, so it is still there, but you have to be on the edge of a spinout before it intervenes.
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 12-04-2020, 09:43 PM   #11
kdm123
Is there any way around this issue with low tire pressures not allowing stability control to be turned off--if in fact low tire pressures are the issue? I run slicks with a 20 psi cold pressure, and I think this is the problem. I did three runs today, and for some reason it did allow me to turn of the SC before one of the runs but not the other two. I tried to d/c it both ways--by holding down the TC button and by pressing it twice after selecting Race mode. So frustrating!
Old 12-05-2020, 04:54 AM   #12
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
Nice, Thank you....
Bangkok_ZL1 is offline   Reply With Quote
Old 12-05-2020, 08:34 AM   #13
Yves ZL1
Yves ZL1's Avatar
That doesn’t work on mine also
Old 02-24-2021, 10:35 PM   #14
kdm123
I'm wondering if disabling the TPS sensors will fix this problem of the stability control not turning off when low tire pressures are sensed. Has anyone tried this?
