![]() Drives: camaro zl1 1le Join Date: Mar 2020
OEM brakes or aftermarket?
Can anyone confirm the front rotor Part numbers #177 1247. I need to replace mine due track duty as they now have warped. I got about 25-28 20min sessions out of the front. Would an aftermarket be better vs price? 2019 ZL1 1le
Your brakes have not warped. I guarantee this.
You have managed sufficiently smear the OEM pad over the surface of the rotor. Creating wobbly brake feeling. If you have in fact warped the ZLE rotors, something is wrong.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
![]() Drives: 2019 ZLE Join Date: Jul 2020
What he said. It's pad deposits. Driving around town with light brake application, so as to not create much heat, will scrape the rotors clean. You can accelerate that process with a more aggressive track pad. I kept a set of Hawk blues for that job. Super aggressive pad. Especially when cold. It will clean rotors in a few stops. But don't leave them on for prolonged periods. I forget about them once and a couple weeks later I notice the slots in my rotors were almost gone. Needless to say they were squeaky clean. The above was for my S4. Not my camaro.
![]() Drives: 20 SS 1LE Join Date: Jun 2020
I've had good luck removing pad deposits by just hosing the rotors a few times to get a thin layer of rust on them and then going for a drive.
John Hale
multi time solo nats runner up :( |
#5 | |
I still wouldnt mind having the extra set of rotors on hand.
![]() Drives: 2019 Camaro ZL1 A10 Join Date: Mar 2019
Was just about to order new rotors on my 2019 ZL1 when I found this thread. 25K miles. Braking is a little wobbly from 70+mph, a little sketchy to brake hard. I did drive it from DC to Vegas and back in August plus once on the track - pushing it when safe - so the rotors could've gotten heated up. You guys think it's just pad deposits or change out the rotors too? Thanks a lot.
#7 | |
![]() Drives: 2017 Hyper Blue 2SS Join Date: Mar 2017
#8 |
#9 |
![]() ![]() ![]() ![]() Drives: 2018 ZL1 (SOLD) 992 GT3 (current) Join Date: Aug 2013
Yes just ran into this same issue, thanks to the info on this thread, a few fast hard stops and the vibration is gone! And to think I almost bought brand new rotors!
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
#10 |
OK perhaps I was little quick on that one, it looks like I need to do some more fast hard stops… that doesn’t work I’ll take the rotors off and use some sandpaper
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
These two things will help anyone concerning brakes and uneven pad transfer:
There's tons of info on brakes here. Once we understand what is going on, it's no longer a mystery. https://centricparts.com/resources/r...ry=Whitepapers In particular, this one: https://centricparts.com/getmedia/bd...c-8-2018_1.pdf When uneven pad transfer happens, here is the simple fix: https://www.amazon.com/dp/B007INTEMC...v_ov_lig_dp_it
"KEEP THE FAITH"-Fbodfather |
