![]() Drives: 2018 2SS Convertible MBM/Kal Join Date: Feb 2018
Pads for 6 piston fronts and stock 4 pot rears
It’s about time to replace the pads on my 18 2SS convertible.
It has the 6-piston Brembo Performance fronts and regular 2SS 4-pot rears. (Although in matching red calipers.) What are THE recommended pads for the front AND rear? Compared to stock; I’m looking for LESS brake dust, equal or less noise, equal or somewhat better (aggressive) street/backroads driving performance. I’ve searched a bit, but haven’t found the specific recommendations I’m looking for. Thank you all for your time and expertise!
2018 2SS Vert. MBM/Kalahari. MRR FS01’s with 285/305 MPS4S. Black Bow ties, A8, MRC, NPP, 6-piston Brembo’s w/ matching rears, OEM Ground Effects/Splash Guards, 8”/Nav. Borla S-type, Pray IM/TB, RotoFab.
Past DD’s of note: 2013 Caprice PPV. (“Company” car.) 1998 Cadillac STS 1996 Impala SS 1969 Cadillac DeVille Convertible 1993 Corvette 1991 Mustang 5.0 LX 1973 Alfa Romeo Spider 1986 Mustang GT T-top 1964 Falcon Sprint Hardtop. (First car, still have the key!) |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
z26 or oem brembo
#3 | |
![]() ![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
IMO, the stock pads offer the best balance of what you're looking for. Might suggest a ceramic coating or something similar on the wheels and calipers to reduce the amount of brake dust that sticks so you don't have to give up braking performance, especially if your version of spirited backroad driving involves heavy enough braking that you start to smell the brakes.
2017 SS 1LE.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Z26 will be much less dust but reduced braking perf, too, noting you want something that's still aggressive. I would kind of concur with wheel coatings and staying OE/Brembo pads.
Thanks for the info. Very helpful.
It has the OEM pads that came with optional 6-piston Brembo fronts, and the rears are the same. I’ll likely stay with the OEM pads.
![]() Drives: 2019 Camaro 2SS Vert Join Date: Apr 2020
I couldn't stand the brake dust of OEM so I went with Z26. Mine is a daily driver but I let it loose on weekends through the twisty mountain roads up here in BC. Haven't had an issue yet.
