Old 10-02-2020, 01:06 PM   #1
RyanR623
Drives: SS A8, NPP, Red Hot
Epoxy Recommendations
I bought a ZLE wing and don't trust the acrylic double sided tape that comes with it to attach the winglets. Any recommendations on permanent plastic to plastic epoxy?
RyanR623 is offline   Reply With Quote
Old 10-02-2020, 01:19 PM   #2
ctrlz
I'll chime in first. This is easily the most durable, weather-proof epoxy I have used. Long working time.
https://www.westsystem.com/specialty...poxy-adhesive/
https://www.amazon.com/West-Systems-.../dp/B002IVAJ6Y
Old 10-02-2020, 01:27 PM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
You’ll be fine with the tape. use an epoxy and if it ever breaks and you need to get it off you’re gonna ruin the fender… The key with the tape is to make sure you have an absolutely pristine clean surface that’s been rubbed down with alcohol.
Old 10-02-2020, 01:43 PM   #4
OB0001
OB0001's Avatar
Drives: 2018 Camaro SS A8 "Dark Knight"
parts have been mounted with double sided tape for about 20+ years with no problems
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake
OB0001 is offline   Reply With Quote
Old 10-02-2020, 02:52 PM   #5
mikeman
Drives: 2015 Camaro
3M makes an adhesion promoter that works great for things like that. It's much better than alcohol.
mikeman is offline   Reply With Quote
Old 10-02-2020, 05:21 PM   #6
wwiiavfan
Drives: 2017 1SS Hyper Blue
I have window vent visors held on with 3M tape that haven’t budged a millimeter in the 17 years I’ve had my truck. Wind, ice, automatic car washes, no problem.
wwiiavfan is offline   Reply With Quote
Old 10-04-2020, 12:35 PM   #7
ember1205
Hot Camaro
ember1205's Avatar
Often times, adhesion promoters will soften the clear coat / paint - I would stay away from them in most situations unless there is a specific need.
OP - My side skirts are held on solely with 3M 4922 tape and haven't budged at all. These things are like 7 feet long and are subject to deflection forces from air moving around the car at speed. Here are some tips when gluing items like this:
- Ensure that all surfaces are clean, dry, and smooth
- Ensure that you "get it right" the first time - don't touch the pieces together, pull them apart, etc.
- Ensure that you apply sufficient pressure to promote adhesion
- Add heat if you're able (I used a hair dryer to keep the rockers / skirts warm for over 20 minutes once I installed each skirt, and I kept pressure on the pieces to hold them together).
- Don't drive the car for up to 48 hours after installation (look up the details of how long it takes for these tapes to fully cure) of everything to ensure that the adhesive on the tape can fully meld itself into place before air movement starts applying opposite pressure on it
Old 10-04-2020, 02:21 PM   #8
activepat
activepat's Avatar
Drives: Red Hot SS 1LE
Gotta vouch for this stuff. It's bullit proof.
activepat is offline   Reply With Quote
Old 10-04-2020, 04:02 PM   #9
Drags1998
Drives: 15 SilveradoLTZ,162SSVert BlazerRS
The 3M tape is VERY strong, I have a trailer where that tape holds all of the outer skin together!!!! You would destroy the skin before the tape fails!!!
Drags1998 is offline   Reply With Quote
Old 10-04-2020, 04:05 PM   #10
mikeman
Drives: 2015 Camaro
I have used 3M brand adhesion promoter exclusively for many projects over the years, including my Camaro, and it has never softened the clearcoat.
If the vehicle or part has been repainted with some cheap paint, then all bets are off. I've only used it on factory OEM paint and high quality prepainted aftermarket parts. Never had a problem.
Old 10-06-2020, 09:14 AM   #11
RyanR623
Thanks for all the recommendations! I'll look into each one.
