![]() Drives: 2017 Camaro 2LT 1LE, 1962 Corvette Join Date: Sep 2020
Windshield Washer Fluid Pump Replacement
Has anyone replaced a pump on the 2017 V6 1LE?
I have seen the replacement of the 2015 with the bottle on the drivers side. Mine is on the passenger side I dont want to assume its the same just on the other side but is it? |
![]() Drives: 2016 2SS A8 Convertible Join Date: Aug 2010
I replaced my 16 SS removed wheel. Remove a couple torq bit screws from inner liner, tug liner out of way a bit. Tank just inside next to bottom of fender. Remove hose = fluid runs out. Remove harness. Pull out pump. Reverse process.
![]() Drives: 2017 50th Camaro SS Join Date: Jul 2016
I replaced mine with an Alky Control Meth Pump. LOL
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
