Old 10-02-2020, 03:34 AM   #1
WarlockCamaro
WarlockCamaro's Avatar
Drives: 2016 Camaro 1SS
Exclamation I need help regarding my brakes ASAP!
Hello guys, I bought a new set of brake rotors and pads for my 2016 Camaro SS, I thought it came with the stock 4 piston brembos all around but that was not the case. The fronts were upgraded to the 6 piston brakes that the 1LE has with the bigger caliper, rotor ad pads. I already got the brakes and rotors for the stock 4 piston brakes and I was thinking instead of returning those rotors and pads I should keep them and downgrade my front brake setup to the stock 4 piston brembos to keep the costs down. I already found a set of really cheap used calipers and brake fluid harnesses for around $300 bucks and the labor I'll do myself.
What I wanted to ask you guys is. . . what else do I need to make the swap,do I need just the calipers and the harnesses or do I need other parts too. I went and I looked at the stock 4 piston brakes and from the pictures it looks like I just need the harness and caliper.
If you guys have any information that'll be awesome, but besides that pretty much it.
Thank you!
WarlockCamaro is offline   Reply With Quote
Old 10-02-2020, 08:10 AM   #2
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
I would return what you have and get the proper set. Why give up better braking and have to spend 300 on calipers to do it.
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 10-02-2020, 08:33 AM   #3
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I agree. I'd keep the 6 piston brakes.
476 rwhp/440 rwtq (sold)
Old 10-02-2020, 08:34 AM   #4
MrChrisLS3
Drives: 2018 1SS M6
First concern would be trusting "really cheap used calipers and brake fluid harnesses".
Secondly, you already have the 6 piston rotors and pads.
Third, considering that the rotors can be turned at least once, and that brake pad replacement is a relatively infrequent item, is the difference in parts cost really worth all of that?
Not to mention that down the road, if you want to sell or trade the car, the six piston brakes will make it more desirable.
MrChrisLS3 is offline   Reply With Quote
Old 10-02-2020, 08:39 AM   #5
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I agree with all replies above. Keep your 6 piston front brakes as they were a very nice upgrade/option to your SS!��
Old 10-02-2020, 11:05 AM   #6
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
leave the downgrade, take the cannolis and keep the 6 piston setup.
nancygrl is offline   Reply With Quote
Old 10-02-2020, 11:07 AM   #7
WarlockCamaro
Well I've searched all around for brake rotors and pads that fit the front brakes, but the only ones that I can find were the ones from GM. A single rotor is $600 bucks. . .for a single rotor. In total I'd spend roughly $1400 on only rotors and pads for my front brakes only! If I switch over to a 4 piston set it, it would save me alot of money in the end and besides I'm never going to go on the track or do any serious driving with this car it's my daily.
Listen if you guys can find these rotors and pads for a fair price then I'll consider returning my rotors and pads. For right now I think swapping over to a cheaper set-up to save me the headache of buying a whole new set that costs way too much for what they are.
Also again, what else do I need if I switch over the "cheap brakes" I found are used OEM and just come with the caliper and fluid harness do I need anything else to swap over?
Thank you.
Old 10-02-2020, 11:23 AM   #8
closs2sx
closs2sx's Avatar
try rockauto.com
MY Car
2015 Z06 Z07
Dads Car
2013 ZL1 vin 963
6 Spd Manual
Old 10-02-2020, 11:25 AM   #9
wwiiavfan
Drives: 2017 1SS Hyper Blue
You will want to look to the aftermarket for rotors and pads. The factory rotors are a 2pc design for ultra high performance braking. Aftermarket companies like Powerstop offer 1 pc rotors for your application that are waaay less money than Chevy’s. They make good brake pads for daily drivers too.
wwiiavfan is offline   Reply With Quote
Old 10-02-2020, 11:35 AM   #10
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
Agree, price the PowerStop kits.
craigss50 is offline   Reply With Quote
Old 10-02-2020, 11:36 AM   #11
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
im super confused lol why would you want to take it off?
Old 10-02-2020, 11:37 AM   #12
closs2sx
closs2sx's Avatar
https://www.rockauto.com/en/parts/gm...193,rotor,1896
MY Car
2015 Z06 Z07
Dads Car
2013 ZL1 vin 963
6 Spd Manual
Old 10-02-2020, 11:40 AM   #13
Dagstar
Dagstar's Avatar
Drives: 2016 Camaro SS
If you need to replace the rotors for the GM 6 pistons, you can save money and buy these by DBA. It's the disc replacement only (no rotor hat), so you will need to swap yours. I bought mine for $585 total(both fronts) after a 10% coupon from buybrakes. I also changed my pads all around to Powerstop as others have, part #'s Z26-1405 (6 piston fronts), Z26-1718 for rears. They cut down on brake dust a lot, but from what I've heard give up some performance at the track.
2016 Gloss Black Camaro 1SS, A8, MRC, 6-Piston BBK
Whipple, LT4 fueling, AlkyControl, Kooks, Borla, Roto Fab, Mightymouse, aFe, Apex, C7 Carbon, etc...
Dagstar is offline   Reply With Quote
Old 10-02-2020, 03:37 PM   #14
RKeeton
Drives: 2013 BMW M3
Thank you!
Based on the picture of the six piston brake upgrade on Chevrolet's website, the only thing left is the backing plate. It may not be required to be replaced though. It sounds like you got everything you need.
RKeeton is offline   Reply With Quote
