Old 09-30-2020, 11:51 AM   #1
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
Whipple on Stock SS Clutch
At the track (drag racing), how much do you think this stock SS clutch can take with my whipple setup? I have been leaving the line at 4500-5000 with a smooth semi-quick clutch release with high 1.6x-1.70 60 fts. Kind of hard to really explain, but I havent smelled the clutch yet and I am not hanging on to it to much. I have about 30-40 passes on the car.
Looking to try and send it this Sunday, maybe start around 3500-4000 and almost dump the clutch and see what happens. Trying to get into the 1.50's for the 60ft and hoping for a 10.50 or better pass.
Running MT ET Street R bias 28x11.5-17, with DSS axles and Gforce AL DS. Figure the worst that can happen is a smoke the stock clutch.
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 09-30-2020, 11:58 AM   #2
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
Darn impressive for OEM equipment, IMO! Following...
Tim M is offline   Reply With Quote
Old 09-30-2020, 12:23 PM   #3
laynlo15
Drives: 2022 Lt1 A10
Its amazing how much the stock parts can take. The Camaro diff finally broke after 240 plus passes. The stock tranny and converter are still in the car and it has 13000 miles on it so who know how long your clutch will hold up but with those 4500 rpm launches it sure ain't helping it any. You got it running good and hope you can get into those 1.50 short times your hoping for. Good luck.
Old 09-30-2020, 02:29 PM   #4
Jhunsberger
What did you replace the diff with Stock SS stuff, is the ZL1 stuff any different? What actually broke? I guess this could be the other potential weak point, but gotta think it would push thru the clutch before breaking the diff.
Old 09-30-2020, 03:16 PM   #5
laynlo15
Its a stock diff and I'll need to find out since I sold it a few moths back. I still tune it for the new owner.
Old 10-01-2020, 07:02 AM   #6
L78toLT1
L78toLT1's Avatar
Has anyone successfully installed an edif from a zl1 or ss1LE in a standard ss?
Baby Blue
Old 10-01-2020, 11:10 AM   #7
Jhunsberger
Anyone have a good suggestions for a good replacement clutch and what all is needed? should the slave and throwout bearing be replaced?
McLeod, Mantic, Tilton, Monster, ACT, Center force
Old 10-06-2020, 08:13 AM   #8
Jhunsberger
Maybe this post should really be in the transmissions section, BUT I never made it to the track on Sunday since some test hits on the street Saturday broke something in the actual trans. So I will be pulling the trans, getting it beefed up and rebuilt, also throwing a Mcleod or RAM clutch in at the same time and a hurst short shifter.
Old 10-06-2020, 09:27 AM   #9
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Ouch! Good luck with the rebuild. You’ll be back at it in no time.
Old 10-06-2020, 09:37 AM   #10
LT1ornothing
Drives: 2020 LT1 M6
I'd keep it here, it's most definitely forced induction related. I was also impressed with your 60ft on oem clutch. Bummer about the transmission, I'd imagine all that torque down low on sticky tires had something to do with it. Hope its up and running soon, should be able to cut a 1.5 60 ft when all said and done, that should hurt some feelings for some automatic guys out there
