Old 09-29-2020, 11:57 PM   #1
savagecamaro
savagecamaro's Avatar
Drives: 2017 Camaro 2ss
Coming from N/A to Procharger
Currently my set up is
Speed engineering headers (full exhaust)
Msd intake
Lt5 TB
Stock intake
E85
I know I will lose my flex fuel and go to 91 (I'm in CA) question is, how safe will I be running about 9psi of boost? What else do y'all recommend? I've been reading but still confused.
savagecamaro is offline   Reply With Quote
Old 09-30-2020, 05:27 AM   #2
NYblack1le
Drives: 2018 1SS 1LE
Who’s going to be tuning the car ? I would consult with them on whats safe.
NYblack1le is offline   Reply With Quote
Old 09-30-2020, 06:38 AM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Msd intake
Lt5 TB
Stock intake
E85
9 psi on 91 octane will definitely need some timing pulled out to prevent knock. I’d definitely suggest upgrading your fuel system to at least the LT4 (in-tank pump, high pressure fuel pump, and injectors) and then you could blend in some E to help protect the stock pistons and add some timing back in. This has been discussed *many* times on this forum, so definitely worth doing a search.
Old 09-30-2020, 02:21 PM   #4
QuickSilver1LE
Drives: 2018 Camaro 1LE
Msd intake
Lt5 TB
Stock intake
E85
Doubtful you will have enough high pressure fuel without a camshaft or methanol. It is usually a struggle to get 7 psi with the pressure maxed
QuickSilver1LE is offline   Reply With Quote
Old 10-01-2020, 12:35 AM   #5
savagecamaro
We'll have to see. My tuner said I'll be fine with 8psi
I know on these forums, people say this and that, so kinda the same thing on this thread
Old 10-01-2020, 04:34 AM   #6
MSU120
+1.
Upgrade your fuel system. On 7lbs with PCs canned tune, I was getting/approaching lean towards the top with stock fuel.
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD
MSU120 is offline   Reply With Quote
Old 10-01-2020, 06:39 AM   #7
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
It would be a better move to upgrade the fuel system, run less boost, and keep E85 or even a lesser mix. Make the same or even a touch more power with 6psi on E vs 8psi on pump with stock fuel...that equals less heat and happier pistons.
Old 10-01-2020, 11:24 AM   #8
savagecamaro
What about running meth?
Old 10-01-2020, 11:43 AM   #9
KingLT1
KingLT1's Avatar
Meth works...it's a cheaper alternative but there are pros/cons with it like anything else. The only con to fueling with strictly DI is cost. Cons to fueling with meth is you have to lean fuel system out to run it. If it fails then you go lean. Meth pumps seem to have a shorter life span. It's just another variable in the system. However installed and setup correctly it works well.
Old 10-01-2020, 10:03 PM   #10
savagecamaro
Okay. I just bought an alky meth kit so we'll see how that goes.
Old 10-02-2020, 08:56 AM   #11
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
imo, upgrade to lt4 fuel system, add meth, add e85, pulley procharger to wherever boost you want to be at.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 10-02-2020, 08:40 PM   #12
savagecamaro
No funds in the bank for the lt4 system. So until then, meth will have to do for now.
