![]() ![]() ![]() Drives: 2018 ZL1 1LE and 1991 Z28 Join Date: Jan 2009
Clunk from front brake calipers?
New owner of a 2018 ZL1 1LE. Sometimes when I'm pulling out of my garage or anywhere for that matter, when I'm driving slow maybe 5-10mph, I hear a clunk noise when I push on the brake pedal. Anyone have this issue? If so is this normal? TIA!
In the garage: 2018 HBM ZL1 1LE // 2013 ZL1 (sold) // 1991 Camaro Z28 5.7L // 2022 Audi E-tron SUV (wife's car) // 2002 Camaro SS (sold)
![]() ![]() ![]() Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Check torque of caliper bolts, make sure pads are correct size, anti-rattle spring, and pins are properly seated, torque bridge bolt, then torque wheel lugs?
Ok ill keep that in mind and have the tech at the chevy dealer check it out for me when I bring it in for fluid changes. Thanks for the advice.
Thank you Al Oppenheiser!
Something is loose.
Check all the things. Seriously, check the lugs, calipers, suspension components, steering links, strut tower... all the things. |
![]() ![]() Drives: 2020 SS 1LE Join Date: Aug 2020
Often that's an indication that one of the bracket bolts that holds the caliper is loose or missing. If its completely backed out (top or bottom bolt), you might even see the caliper rotate slightly CW or CCW.
Have someone stand outside your car and watch while you move slowly forward & brake. Then backward and brake. Look at one wheel at a time. You'll either visibly see or hear where the clunk is coming from. Report back. Good luck! |
![]() Drives: Zl1 1le Join Date: Apr 2018
Make sure its the brakes and not the shocks...
#7 |
Thanks for all you guys input. Will definitely check them out on my own for anything loose before I take it out again.
#8 |
Anyone got the torque specs for the calipers and caliper bracket bolts? Im at least check those tomorrow. TIA!
#9 |
Nevermind. Found it. Thanks again everyone.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
#11 |
I checked the caliper bolts and they were torqued to spec. calipers look ok. pads are solid in place. don't know what else it could be causing the clunking noise. still does it. will have the dealer check it out when i take it in. will be soon. thanks.
#12 |
...all the things.
#13 |
Agreed. Being this is a 2018 (previously owned?) the owner could of stripped off aftermarket parts in a "rush" and put back to OEM, or moved the camber adjustment etc... anything. Something IS loose. Standing by for what is found. Best of luck narrowing it down!!
#14 |
Any further luck with this?
