Old 09-25-2020, 07:40 AM   #1
SS.Sanchez
SS.Sanchez's Avatar
Drives: 2018 Redline Camaro SS
CEL after exaust install
Hey guys! I just installed the Corsa Xpipe last night on my A8 and the whole way home from the shop (about 17 miles) I had no CEL all good. This morning on my way to the gym (<1 mile) it turned to v4 mode a few times and threw a CEL. And yes I did plug in the old AFM actuators and zip tied them up in the car. It might just be that the zip ties got in the way of the actuators but am I going to have to clear the CEL or will it automatically go away if I fix the afm issue?
SS.Sanchez is offline   Reply With Quote
Old 09-28-2020, 11:07 PM   #2
Juiced1
Drives: 2012 2SS CAMARO 45th
Did you check the cel? Make sure it's for the exhaust first. It should go away though after a little bit if you fix the issue but having it cleared shouldn't take more then a couple minutes.
Juiced1 is offline   Reply With Quote
Old 10-02-2020, 03:25 PM   #3
Chris C 1SS 1LE
Chris C 1SS 1LE's Avatar
Drives: 2017 1LE
P0409 Cat Below Threshold, I'd presume. It's drivers side where the X slips on the cat. You took off the copper braided gasket on the cat pipe I bet, right? Had same/did same. Dealership fixed it. 200 miles, no code, new cat with the braided copper gasket.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube
Chris C 1SS 1LE is offline   Reply With Quote
