Old 09-25-2020, 12:31 AM   #1
Val Walkinshaw
L8ap3x
Val Walkinshaw's Avatar
Drives: 2018 2SS 1LE
New service bulletin-2020 GM V8 motor valve spring issues.
https://gmauthority.com/blog/2020/09...gm-v8-engines/
The service bulletin indicates that vehicles equipped with certain GM V8 engines may produce a service engine light along with a misfire and strange engine noise. The issues can be linked back to faulty valve springs, with the bulletin instructing the service department to check for a broken valve spring and, if necessary, perform a cylinder leakage test on the cylinder with the broken spring. The bulletin also says that “if no cylinder leakage is observed it will be necessary to replace all valve springs on both banks if the vehicle is built between June 1, 2020 to September 15, 2020.”
The bulletin also indicates that the above fix only applies to the following 6.2L GM V8 engines: L87, LT1, LT2 and LT4. For all other current GM V8 engine RPOs (L82, L84 and L8T), the service department is instructed to “just replace the affected valve spring,” and that if they determine there is a cylinder leakage, it “will be necessary to inspect further to determine the extent of the engine damage to determine correct repair required.” GM is also requesting that the service department send back valve springs from affected engines for further inspection.
Val Walkinshaw is offline   Reply With Quote
Old 09-25-2020, 12:45 AM   #2
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
So I am assuming it's a bad batch, then?
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 09-25-2020, 12:48 AM   #3
Val Walkinshaw
L8ap3x
Is this the suppliers version of car covid?
Old 09-25-2020, 01:23 AM   #4
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Glad my 2020 2SS was built last December...
2SS Capt is online now   Reply With Quote
Old 09-25-2020, 01:30 AM   #5
UnknownJinX
At least it's not as bad as the Subaru and Mazda diesel valve spring recalls, which are more of a design issue than a supplier issue.
Current:
Past:
Old 09-25-2020, 07:58 AM   #6
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Reminds me of my 2010 2SS with the LS3 and the broken valve spring I had replaced under warranty in 2012! Come on GM, stop putting inferior parts in the engines now!
Old 09-25-2020, 08:28 AM   #7
Orangeman13
Orangeman13's Avatar
Drives: 2023 Black Camaro 2SS
so if our car was built in July 2020 should I take it in to the dealership today?
Orangeman13 is offline   Reply With Quote
Old 09-25-2020, 08:37 AM   #8
LT4Greg
LT4Greg's Avatar
Orangeman, I would contact your dealer and talk to the Service advisor or Service Manager and ask them about this news and they will advise you. Don’t panic!��
Old 09-25-2020, 08:51 AM   #9
Petrol Head
Drives: Fast if no one's looking
The real question is HOW did the batch become faulty? They're the same springs that have been on every LT1 in both Camaro and Corvette since C7 LT1 production started for the 2014 model year. What did the factory do differently in the production process?
Petrol Head is offline   Reply With Quote
Old 09-25-2020, 09:00 AM   #10
LT4Greg
LT4Greg's Avatar
Yeah I agree with that Petrol Head. Could be that GM used a different part manufacturer which was cheaper than before or other factors causing the problems. My ZL1 LT4 maybe a ticking timebomb waiting to go off due to some LT4s having defective oil pumps and for that reason mine will stay stock until the drivetrain warranty is up.
Old 09-25-2020, 09:25 AM   #11
Venomcustom
Hard to want.
Venomcustom's Avatar
Drives: 2020 red hot 1SS 1LE
My car was built in July. I’m going to call the dealer today and see what they have to say. I’ll report back.
Venomcustom is offline   Reply With Quote
Old 09-25-2020, 10:01 AM   #12
mikeman
Drives: 2015 Camaro
The new C8 seems to be having a big problem with this. More than a few cars over on the Corvette Forum reporting issues with cracked valve springs.
Also, it seems if this problem develops, it happens early like within the first hundred or so miles of ownership. So, I think if you already have a thousand or more miles, you're probably safe from having the cracked valve spring issue.
mikeman is offline   Reply With Quote
Old 09-25-2020, 10:52 AM   #13
Thill444
Drives: 2020 SS1LE Shadow Gray Metallic
Mine was also built in July. Let me know what they say. Obviously I have any engine issues/codes/faults I will stop driving and make the dealer aware, but if there is something we can do proactively would be good to know.
I am just under 500 miles, many of the C8's I have seen with the valve spring issues seemed to have issues under 100 miles, but who knows.
Thill444 is offline   Reply With Quote
Old 09-25-2020, 11:03 AM   #14
Venomcustom
Hard to want.
Same here. I have 430 miles on the car.
