![]() ![]() ![]() ![]() Drives: 1LE Join Date: Sep 2017
Absolute lightest available 18" rims?
Much appreciated!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
all it takes is cash
Drives: 2018 LS V6 1LE; 2000 BMW 540i 6MT Join Date: Jan 2017
Apex FL-5 are very light, 18x10 weighs 20.5#, and 18x10.5 weighs 21#. https://www.apexraceparts.com/our-wh...ution-fl5.html
The 18x10.5 may be the best choice, so that you get more performance out of 275-305 width tires. I have a set of the 18x10 on my LS 1LE (FE3 suspension), and I really like them. With a 5mm spacer, they clear my strut. Note, this is a BMW wheel, so I use plastic rings to make them hubcentric. (I am about to fix this with some custom 12 mm bolt-on spacers that will have BMW hub spacing.) |
![]() Drives: 1985 Oldsmobuick Join Date: Oct 2012
Obviously HRE and Forgeline make some pretty light wheels.
I don't have any experience with them, but Litespeed offers all of their wheels in forged magnesium as an option: https://www.litespeedracing.com/technology |
Thanks!!!!!!!
![]() Drives: Honda S2000 Join Date: May 2019
I have Apex 18x10s they do feel quite light. They aren't crazy expensive either
#7 |
![]() Drives: Chevrolet Camaro SS Join Date: Apr 2019
18x10.5” Superspeed RF05RR = 19.8lbs
#8 |
![]() Drives: 2017 Camaro 1SS Join Date: Nov 2018
18x10.5 +27 TSW Bathurst is 20 lbs. and reasonably priced. You will need a 10 mm spacer and extended studs to clear the front strut though.
#9 |
![]() ![]() ![]() ![]() Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
you want light and strong. Forgeline or bc forged.
#53 F Street
2025 FS National Champion 2025 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 |
#10 |
Thanks for replying ya"ll
#11 |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
FINSPEED in Austin will make whatever you need including non-normal widths and offsets. Not cheap, but, like your other toys, you asked for the lightest not the cheapest.
https://finspeed.com/ |
#12 | |
Heater box will be gone too...25lbs. A little bit more work and i believe I can chop a total |
