#1 | |
![]() Drives: 2020 SS1LE Shadow Gray Metallic Join Date: Feb 2018
Possible Valve Spring Issues
My car was built in July.. Lots of C8's are dropping like flies right now so I can only assume some Camaros will be affected
Hard to want.
Drives: 2020 red hot 1SS 1LE Join Date: Aug 2017
My new SS 1LE falls in those months as well. Let’s hope we don’t have this issue.
Just checked and it’s a July car as well. Last edited by Venomcustom; 09-24-2020 at 11:13 AM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
Probably bad heat treat.
2012 Yukon XL Denali w/ 6.2 AWD |
![]() Drives: 2020 Camaro ZL1 1LE Join Date: Mar 2020
I haven't even picked up my new 21 1LE and it was built on August 8th. I don't think I'm going to wait for an issue. I think I'll just pay the dealer to replace them. A LOT of Corvettes have popped up with the issue already.
Talked with Chevrolet here. They haven't had a LT4 car recalled yet. Talked with Hennessey who confirmed my stock single springs have been replaced with PSI dual springs (which I might have to discuss with a dealer someday)
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#7 |
![]() Drives: Chevrolet Camaro LT1 Join Date: Oct 2020
Issue is affecting new cars, too. I just picked up a 2021 Camaro LT1 and 260 miles into it, the car left me stranded on the freeway. Cause: Broken Valve Spring. SMH
#8 |
Hard to want.
#9 |
They replaced all the valve springs and ran a leakdown test. They indicated that there was no additional damage... I called Chevy and opened a case. Still haven't heard back from them. So far, the car is running fine.
#10 |
![]() Drives: 2018 Camaro 2SS, redline edition Join Date: Jun 2013
Sorry to hear about that. My build date for my 2021 2SS is the week of November 16.
Please keep us posted if you have any other problems. |
#11 |
#12 |
Hard to want.
#13 |
Thanks and I hope you have no other problems with your vehicle
#14 |
![]() ![]() Drives: 2015 Camaro Z/28 Join Date: May 2009
My 2021 was built on 8/26. Got 450 miles on it as of this weekend so far so good. Hoping mine does not have the valve spring issue.......ugh. First oil change will be this Friday.
2015 Camaro Z/28 - Red Hot
1978 Trans Am Y88 Special Edition 400/4 speed 2001 Mecham Trans Am #3 - 7.0L LS1 |
