Old 09-18-2020, 10:10 PM   #1
Wes12
Drives: 2017 camaro ss fifty A8
Headers without tune ?
Hey guys I have some headers on the way that I wanna install myself. My tuner is a little over a hour away do you think I will be okay to drive that far without a tune ? I just don’t want the car to go into limp mode or anything on the way there
Wes12 is offline   Reply With Quote
Old 09-18-2020, 10:53 PM   #2
Fraxum
Fraxum's Avatar
No problem. No risk there. You can easily run LTs without a tune for as long as you wish. But occasionally you need to turn off a couple of CELs. That is mostly all a tune does to assist with LTs anyway. Been there done this more than once.
Old 09-19-2020, 12:22 AM   #3
s346k
s346k's Avatar
Drives: like an old lady
youre fine. if you delete the cats and then drive it you will end up with some permanent codes. the tuner can take care of the cel.
Old 09-19-2020, 07:14 AM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Don’t do it. On a ‘17-up with the E92A you will get permanent codes that will stay in your ECM history, and will show up at inspection time. Have your tuner put the dozen or so header & cat-related codes to “No Error Reported” while you have the stock exhaust on. Then do your header install. Then have the tuner tweak the calibration.
Old 09-19-2020, 08:07 AM   #5
Wes12
My state doesn’t check emissions at all. So should I worry about it you think ?
Old 09-19-2020, 09:24 AM   #6
Speedracer106
Drives: 2020 Camaro ss
Ask someone that knows for sure before you do it. Seems I've heard that once the permanent code is thrown, I think the cel is on until you put stock cats and stuff back on and drive it. Just make sure you all someone and get a definite answer.
Speedracer106 is offline   Reply With Quote
Old 09-19-2020, 09:41 AM   #7
Joshinator99
Moderator
You’ll still be stuck with those codes regardless of whether the state checks them or not, if you ever sell or trade the car it will come up. And you never know if your state will decide to start checking. So, I’d definitely follow the advice I gave earlier.
Old 09-19-2020, 11:24 AM   #8
s346k
s346k's Avatar
the cel can be turned off, but the codes will always be there. i think a gm tech 2 is the only way around it without putting it back to stock.
as suggested, if possible, flash the car with the corresponding emission(s) codes disabled before doing any work.
