Old 09-17-2020, 04:43 PM   #1
neo85
Drives: camaro ss
Conti DSW 06 sizes for stock 20 inch rims on 2ss
Looking to change from standard eagle f1s to the Conti DSW 06 all seasons for the rain etc can someone confirm the exact sizes I'll need for the front and rear? I'm using the standard 20 inch rims.
neo85 is offline   Reply With Quote
Old 09-17-2020, 05:19 PM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Standard tire sizes:
Front: 245/40ZR20
Rear: 275/35ZR20
Old 09-17-2020, 05:45 PM   #3
neo85
Drives: camaro ss
Front: 245/40ZR20
Rear: 275/35ZR20
Thanks for the info bro- do they need to do anything special when changing from run flats to these tires?
Old 09-17-2020, 06:30 PM   #4
Mark114
Mark114's Avatar
No, just swap the tires. The wheels are different widths front/rear so check that they mount the correct tire size to the correct wheels. Maybe reset the TPMS sensors if they don’t put the wheels on the same corner that they came off.
Old 10-12-2020, 12:24 PM   #5
ctrlz
I would also make sure you see the word "outside" on the outside of all 4 tires.
Like Mark said, this is a straightforward swap. And if your tire shop can't get this right... oh, boy!
Old 11-06-2020, 02:13 AM   #6
principia
Drives: Chevrolet Camaro 2SS
Consider BFG g force comp 2 plus a/s. I’ve had these and continental dw06 on another car and much prefer BFG.
principia is offline   Reply With Quote
Old 11-06-2020, 10:24 AM   #7
NYJets12
NYJets12's Avatar
Drives: 2018 1LT Camaro
Did you ever drive with both those tires in the snow ? How are they ?
NYJets12 is offline   Reply With Quote
